09-16-2016, 09:34 PM   #31
Paul the Sunman's Avatar
QuoteOriginally posted by Tonytee Quote
Thanks Paul. I was hoping to receive information regarding issues with the batteries fitting into a digital camera. Any experience in this area?
No. But I guess it depends on the tolerances of your particular camera.
09-16-2016, 10:22 PM   #32
QuoteOriginally posted by Paul the Sunman Quote
Here is the text about AA batteries that are wider now.
However, Eneloop Pro batteries don't have nearly as long a lifespan as the regular Eneloops. Panasonic says they can be recharged up to 500 times, but professional tests say otherwise. In one test, the batteries are still going strong after 60 recharges, but they fail before making it to 100. Another downside of the AA Eneloop Pro is that it's slightly wider in diameter than a standard AA battery, so it won't fit into all devices.
Thanks again,
Tony
09-17-2016, 07:03 AM   #33
Fujitsu is the new Eneloop
Just saying...
09-17-2016, 07:30 AM   #34
For what it's worth, 1st generation Eneloop XX fit just fine in my k100d. They easily cleared 400 shots per charge. If they lasted 60 charges, that's a heck of a lot of photos for the cost. I don't use this camera much these days, so I don't think I've come close to 60 charges. Prior to the "XX" version, I used regular eneloops. They would eventually fade and perform terribly in the camera after a few years. However, a camera is much pickier than many other devices, and I'm still using 9 year old 'faded' eneloops in flashes.
09-17-2016, 04:04 PM   #35
QuoteOriginally posted by BrianR Quote
Thanks for your post. I would like to know the power level of the Eneloop XX. How high a number on the mAh? My K100D Super manual advises to not use less than 2500mAh in the camera.
Much appreciated.
Tony
batteries, camera, charge, eneloops, experiences, flashes, juice, pentax help, photography, sanyo, troubleshooting, wedding, xx
D-LI109 Battery Self Discharge rate / eneloops saintbubba Pentax Camera and Field Accessories 4 11-02-2015 09:28 PM
K-30 Won't Power-up With Eneloops. tabl10s Pentax K-30 & K-50 9 02-09-2015 08:21 AM
Panasonic vs. Sanyo Eneloops GibbyTheMole Pentax Camera and Field Accessories 4 07-23-2014 07:43 PM
Yongnuo YN460 battery, I'm using Sanyo Eneloops Li-on Iksobarg Flashes, Lighting, and Studio 3 01-15-2014 02:05 PM
Eneloops! okto Pentax DSLR Discussion 9 11-09-2006 10:28 PM
All times are GMT -7. The time now is 02:22 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
