07-09-2016, 09:48 PM   #1
Timed Exposure Using Cable Shutter Release
I have tried to do a timed shutter release using two different units on both my K1 and K3 with no luck. Camera in bulb mode.
The camera shutter will open when I press the "timer start stop" button on the unit, the red light will be on, and the unit will start counting down from the selected exposure time (i.e., "long"). However, when the count down gets to zero and the red light goes out, the camera shutter remains open - until I hit "timer start stop" again. It refuses to shut off automatically.
I feel I must be doing something wrong, but I don't know what. (Manual on/off and hold works just fine; just auto timer is a puzzle. And, even though I'm just requesting one shot, I have tried setting the interval time to a few seconds greater than the desired exposure time - no luck, same results).
Any help greatly appreciated.
Thanks much,
Fred
07-09-2016, 09:55 PM   #2
What is the "B" action set to? There are two options. The first holds the shutter open until it is released and the second holds it open until the button is pushed again. On your K-3, it is menu/C/1/7 Bulb (B) Mode Options.
BTW...what wired remote are you using?
07-09-2016, 10:39 PM   #3
Oh...I think I maybe figured it out. Thanks for adding the part about the red light. Is there any chance you have the drive mode set to "Remote Control" or "Remote Control - 3 sec delay"? When using the wired remote, you don't need to use the remote control drive mode. That is for the wireless remote only.
07-10-2016, 08:04 AM   #4
Bingo! Changing the bulb menu setting did the trick.
The unit has a Vivitar label, but is the same as others with different brands.
Thanks Steve
Fred
camera, exposure, exposure using cable, light, luck, pentax help, photography, release, shutter, time, troubleshooting, unit
Shutter release cable for the K-1 AwesomeIan Pentax K-1 8 07-06-2016 02:40 PM
Cable shutter release for the K-01 jerry7171 Pentax K-01 8 11-08-2015 02:28 PM
Shutter Release Cable for K-50 vagrown Pentax K-30 & K-50 5 06-27-2015 11:05 AM
Create your cable shutter release hpiccolo Pentax Camera and Field Accessories 7 09-15-2014 07:48 PM
Pentax K1000 Timed Shutter Release? DodgeMan50 Pentax Camera and Field Accessories 2 01-25-2008 07:48 AM
All times are GMT -7. The time now is 03:38 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
