07-15-2016, 12:24 AM   #1
Louicio's Avatar
Manual focus lens issue
Hi forum,
I am in need of expertise from the wider community. I am hoping someone cant point me in the right direction of what the issue might be.
I have a 100mm f2.8 manual focus lens that doesn't focus correctly. I'm all over little things like the focus grouping not replaced in the right position after being opened etc.
However the lens I have is currently focusing on what seems to be two points. One far off and one closer to the camera.
At infinity all objects in the distance are blurry and when adjusting the focus closer to the camera slightly the objects at infinity become sharp, however the image at a mid distance of approx 10m (30ft) are fairly soft and the image at a closer distance of approx 2-3m (6-9ft) are sharper again. I also are unable to sharpen up the mid distance image by adjusting focus although the lens functions correctly mechanically.
Because of work I will do a more comprehensive test of the focus with a tripod and take video to post before I open the lens up after the weekend but any provided would be great.
Thanks in advance.
07-15-2016, 03:41 AM   #2
QuoteOriginally posted by Louicio Quote
Hi forum,
Thanks in advance.
I have not experienced these issues that you are experiencing. I do know someone who did have these same problems. It seemed that one or two of the optics slipped loose from the adhesives. He did the calibrations and after that he would have great focusing, but shortly the problem returned. The last time I spoke with him he ended up donating the lens to his favorite charity because repairs were much more expensive than what the lens was worth. I do not know if this helps, I hope it does, so good luck with that.
Regards,
Antonio
07-15-2016, 04:00 AM   #3
D1N0's Avatar
Which lens is it?
07-15-2016, 07:10 AM   #4
Is there anything loose (shake the lens does it rattle)? On the occasions I've had funny focus issues it's been due to a loose element.
08-01-2016, 10:14 AM   #5
Louicio's Avatar
Thanks everyone who replied. Just thought I'd follow up with the outcome. Pulled the lens apart (its a Nikon E series 100mm f2.8) and turns out a small metal ring used to space and hold one of the glass elements was inserted backwards allowing it to move and the element was crooked. Replaced correctly and cleaned the glass and works like a treat now! winning!
approx, camera, distance, focus, focus lens, image, infinity, lens, objects, pentax service, repair, service, warranty
Issue with manual focus on 60-250 when using Pentax 1.4x TC Quich Pentax SLR Lens Discussion 11 12-28-2015 07:56 PM
For Sale - Sold: Rare Vivitar K mount 24mm f2.0 manual focus lens w/issue-photos added 17dew Sold Items 5 11-23-2015 08:30 AM
645Z Manual Focus Issue - Is It Just My Camera? iCrop Pentax Medium Format 7 05-10-2015 10:20 PM
how to focus perfectly with manual focus lens? ghiaauto Pentax SLR Lens Discussion 17 09-30-2014 02:37 AM
Manual zoom lens focus issue rage03usa Troubleshooting and Beginner Help 6 01-30-2014 09:46 PM
All times are GMT -7. The time now is 10:11 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
