07-22-2016, 03:47 AM   #1
K3 exposure not works in "Av, Tv, TAv, P" mode
I am newbie and this's the first time to post with my K3 problem:
Shutter speed, aperture, ISO lost ability when I set Av mode even Tv or TAV; and I had to set them manually.
I had tried using Av-Tv-TAV mode, pointing to other scene to shot and press 1/2 ...focus function works very good but camera had the same exposure value as last shot (in manual). So on.
On back display, at left top displays "M" even I set AV-TAv or Tv mode.
AF, green button work very good ...so I must press it every time for knowing (shutter speed, aperture, ISO) and set them in manual.
Things had done: updated latest firmware for K3, change other battery ...
Problem happened 3 days ago. Now I did only use K3 with MF mode
Anyone have experiences helping me or send camera to pentax technician.
Thank you very much.
07-22-2016, 04:33 AM   #2
Have you got Auto ISO on?
07-22-2016, 04:42 AM   #3
Hi Wild Mark
Yes. Normally, I set auto ISO from 100-3200
07-22-2016, 05:38 AM - 1 Like   #4
try taking Auto ISO off and see what happens.
07-22-2016, 06:55 AM - 1 Like   #5
StephenHampshire's Avatar
Sounds like the camera is not reading the f-stop on the lens (hence Av, TAv and Tv modes not working) Try re-mounting the lens and cleaning the contacts- assuming you are using a modern F/DA lens or a manual lens with A on the aperture ring...
07-22-2016, 11:59 AM - 1 Like   #6
QuoteOriginally posted by nguyenlong Quote
I remember reading somewhere that if the mode select dial malfunctions the camera will default into M mode. It's probably a failsafe so you can have full control over your exposure settings even if you can't select a different mode. (Imagine if you were stuck in bulb mode! )
I'd suggest working your mode select dial back and forth to see if it starts working again. Maybe it somehow got some moisture or dust inside that's interfering with the contacts.
---------- Post added 07-22-16 at 03:06 PM ----------
If you still can't figure it out it may be time to look into repair services. In the meantime, practice using it in M mode to get more familiar.
When you half press the shutter the EV indicator in the viewfinder can help you get your shutter / aperture / ISO correct so you can still take pictures. I like using the EV indicator better than using the green button because I decide what to change, so it's more like Av, Tv, TAv modes than using the green button and hoping it can read your mind.
07-22-2016, 02:54 PM   #7
QuoteOriginally posted by TheOneAndOnlyJH Quote
That is my reality for a K5 I own
button, camera, ev, exposure, indicator, iso, k3, k3 exposure, mode, pentax help, photography, press, shot, shutter, troubleshooting, tv
What Mode (AV, TV, M, P,..) Do You Generally Use While Sightseeing jackloganbill Pentax DSLR Discussion 65 12-30-2016 07:24 AM
Lost ability to use to SV, TV or TAV--mode dial only selects AV, M, X, Bulb rweissman Pentax Medium Format 11 07-18-2016 03:12 AM
"Click" in between "C" and "MF" mode on focus selector? K-50 maxwolfie Pentax K-30 & K-50 3 01-29-2015 04:19 AM
What does the "P" stand for in "SMCP-FA" pmighetto Pentax SLR Lens Discussion 2 08-27-2014 04:18 PM
Is Av Shift and/or Tv Shift in TAv Mode possible. robert_s Pentax K-5 3 09-30-2011 09:03 AM
All times are GMT -7. The time now is 09:46 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
