07-23-2016, 06:02 PM   #1
Setting Custom White Balance K-S2
I've been working on a smallish home studio in a spare bedroom and to keep the heat down have decided to use a mix of natural light and continuous LED studio lights (pair of RPS CoolLed 100 and one RPS 20). So tonight I thought I'd take the time to adjust the white balance on my K-S2 for those evening photo sessions. Never used my Expodisc before but time to put it to work. How hard can it be?
Seemed pretty straight forward. Attached the disc, aimed it in the general direction of my primary light took a shot and proceeded to custom white balance. So far so good. Take a shot of a few items against my backdrop and there's a bluish cast. Ok, no prob. Just do it again since I obviously made some error. Same results. Go go my manual and double-check everything. Go to the Expodisc support page and read. Then try again. DANG IT!. Blue cast. After spending and hour and some minutes on this I decide to give a rest, maybe go thru the procedure tomorrow or maybe forget about it and take care of it in post as needed. (I have a color card chart)
Turned off the big light... Turned off the hair light.... turned off the overhead ceiling light... WHAT THE. . . I had the regular room lights on the whole time.
I knew I shoulda stopped at two Landsharks.
There's tomorrow.
07-23-2016, 07:36 PM   #2
One time I tried adjusting my white balance (custom) using different kelvin numbers. I found it quite simple to adjust for no cast, just by trying different kelvin settings. I don't have a KS2, but I would suppose you would have similar options.
You would probably look for the "K" in the custom white balance settings, if it is like my K-3 II options.
You may already know all of this, but I thought I would mention it.
balance, camera, cast, custom white balance, expodisc, k-s2, pentax help, photography, shot, time, tomorrow, troubleshooting
Custom White balance Eder Troubleshooting and Beginner Help 7 04-01-2014 10:23 AM
K-7 custom white balance question rworegon Pentax DSLR Discussion 5 11-16-2013 05:42 AM
Custom White balance acarpov Troubleshooting and Beginner Help 4 02-09-2011 05:16 PM
setting custom white balance grinchicago Troubleshooting and Beginner Help 4 05-09-2010 09:06 AM
Setting custom white balance. Deni Pentax DSLR Discussion 8 07-15-2007 04:05 AM
All times are GMT -7. The time now is 07:08 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
