Originally posted by bluestringer Lens with no aperture ring can not be used with tubes that have no contacts.
+1
those lenses can only be used stopped down to the smallest aperture and that is pretty dark in the viewfinder and LV.
another problem of cheap extension tubes can be that their mount is covered in nonconductive paint, then you can't stop down your lens and it is always fully open -> this problem can be solved by removing the paint or sticking aluminium foil between extension tubes and camera mount.
i think the cheapes extension tubes don't even offer an aperture control lever, then you have to open and close the aperture manually with your aperture ring between focusing, metering and photographing.
