08-03-2016, 09:42 AM   #1
aT0Mx's Avatar
K-5 and manual lenses.
I have been using my k5 for about a month now and something unusual has popped up.
K-5 with fully auto lens (18-55wr and others) works fine.
K-5 with manual focus, auto aperture lens (rokinon 15mm) works fine on auto aperture, but flashes F-- on top lcd and cannot activate live view on any setting
K-5 using fully manual lenses will not activate live view on any setting and flashes F-- as soon as it's in contact with body.
All these lenses work perfectly on my K-R in any mode.
If anyone knows anything that may help it would be apprecited as I'm in the middle of the woods right now.
Thanks.
08-03-2016, 09:45 AM   #2
paulh's Avatar
In the menu, is "using aperture ring" allowed ? Also, fully manual lenses (no auto aperture) work in M mode, using green button metering.
08-03-2016, 10:26 AM   #3
The fact that your Rokinon works fine in A mode and flashes F__ when turned off it does suggest that your "enable aperture ring" setting is currently switched off.
08-03-2016, 11:41 AM   #4
UncleVanya's Avatar
Agree with the above but confused how that dovetails with live view...
08-03-2016, 12:54 PM   #5
Definitely set the aperture ring to 'A' with the Rokinon. If the camera can't enter live view or is behaving erratically, try cleaning the lens mount. Some old lenses also short the wrong contacts and cause weirdness- what fully manually lens did you try?
https://www.pentaxforums.com/forums/54-pentax-lens-articles/110657-how-use-me...k-x-k-7-a.html
08-03-2016, 01:28 PM   #6
aT0Mx's Avatar
Yup. I've not done a reset for a while and forgot to change that custom setting.
It should say it's "prohibited", not "can't activate".
Thank you Paulh.
aperture, auto, camera, flashes, k-5, lens, lenses, pentax help, photography, troubleshooting, view
Pentax K-5, K-5II and K-5IIs rear sync broken with manual lenses Nass Pentax K-5 & K-5 II 17 02-25-2013 05:24 AM
Availability of DXO Profiles for manual K/A/M lenses and K-5 ChrisGVE Pentax K-5 & K-5 II 4 07-29-2012 05:54 PM
K-5 Viewfinder and manual lenses focus problem PiotrKrochmal Pentax K-5 & K-5 II 10 03-08-2012 03:54 PM
Manual lenses and the K-5 NaClH2O Pentax K-5 & K-5 II 10 10-26-2010 01:49 PM
K-5 and K-R with manual lenses, any improvements? ovim Pentax K-5 & K-5 II 48 10-20-2010 02:00 AM
All times are GMT -7. The time now is 02:08 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
