08-05-2016, 06:00 AM   #16
stein's Avatar
Yup, I'd say defective. I also have a SanDisk 32G SDHC UHS-I (Class 10) card and it's noticeably faster than my other two Kingston microSD cards (Class 10). Can't tell the difference in the camera, but once I plug it in to the PC it seems to be faster...
08-05-2016, 06:09 AM   #17
kjphilippona's Avatar
Thanks everyone for the help. I am not looking forward to the headache of trying to get an RMA
08-05-2016, 07:50 AM   #18
Otis Memorial Pentaxian
photolady95's Avatar
QuoteOriginally posted by kjphilippona Quote
With Sandisk, I don't think you'll have a problem with them getting that RMA. They do stand behind their products.
08-08-2016, 05:05 PM   #19
QuoteOriginally posted by Oldbayrunner Quote
When you do be sure to select & use the Full (overwrite) Option selection. That way it will not only format but mark any bad sectors on the card.
One quick question, after full overwrite formatting with this software, do you format the card after installing in the camera?
08-09-2016, 05:52 AM   #20
Oldbayrunner's Avatar
I dont think its necessary but I usually do.
08-09-2016, 06:05 AM   #21
That's reason for not formatting in the camera. After you've used this software, you shouldn't need to format in the camera. Not saying you can't later but initially, I wouldn't.
08-09-2016, 07:09 AM   #22
With the card mounted in Windows you can right-click on the drive letter, choose 'properties', then 'tools' then click 'check' under error checking. It will scan for and try to fix any bad sectors or filesystem errors.
08-09-2016, 07:36 AM   #23
Thanks
09-18-2016, 08:30 AM   #24
QuoteOriginally posted by photolady95 Quote
Well after a half dozen emails sending pictures and test results, I was issued an RMA including a shipping label. This was all good, but after they received the cards, it took another couple weeks and additional emails to get my replacement cards shipped. After receiving them a week later, I used SDformatter to format them , then ran a speed test using SanDisks recommended software, ATTODiskBenchmark. Both cards tested very low read/write speeds 45mbs read and 36mbs write, I'm not very happy with SanDisk at this time. I have re-contacted their CS and uploaded the test results, I think its time to find another
09-18-2016, 08:39 AM   #25
amateur dirt farmer
pepperberry farm's Avatar
I use these in both of my DSLRs with no issues at all:
Amazon.com: PNY Elite Performance 32 GB High Speed SDHC Class 10 UHS-I, U1 up to 95 MB/Sec Flash Card (P-SDH32U195-GE): Computers & Accessories
09-18-2016, 10:49 AM   #26
I have used PNY cards before and also have had no problems, I shall give them a try again.
09-22-2016, 07:10 AM   #27
Well i spent an hour last night with SanDisk Global Customer Care and their level 3 technician informed me that there was nothing wrong with my cards and the speed results were acceptiable for their Extreme Pro sdhc cards !
09-22-2016, 07:21 AM   #28
aleonx3's Avatar
I am no expert in this.. so take it with a grain of salt. I think the speed (read/write) of the SD card depends not only on the card itself (NAND flash) but also on the card reader. Sometimes, the bottle neck could be in the card reader, which is quite common in older equipment. The best result can be obtain if you can find a newer USB 3.0/3.1 SD card reader (possibly with UHS-II bus), that would probably give you better results than what is indicated here. Just a thought anyway.... I agree that your card is acceptable IMO. Another small point, the result indicated is in MB/sec not mb/sec (8 bits per byte).
camera, card, cards, desktop, file, memory, memory cards, pentax help, photography, pictures, sandisk, speeds, troubleshooting
Why is Pentax write speed for same cards so less compared to D7200 or T6i/T6s? superpowerpinger Pentax K-3 & K-3 II 33 07-13-2016 04:31 PM
Can Both Memory cards in K3II be set to Raw? mhsp Troubleshooting and Beginner Help 9 11-28-2015 09:07 AM
Up to 60% off on Sony Memory cards on Amazon RonakG Pentax Price Watch 4 02-01-2015 10:23 AM
Slow write time trishytee Troubleshooting and Beginner Help 7 04-18-2013 09:25 PM
[K20D] Just how fast can it write to memory cards? Reportage Pentax Camera and Field Accessories 15 02-17-2009 12:15 PM
All times are GMT -7. The time now is 04:50 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
