08-04-2016, 10:23 PM   #1
cam_abyss's Avatar
Can't get K-1 to update (resolved)
Somehow I can't seem to be able to get the update prompt by "turning the camera on while pressing the menu button". I'm doing the same procedure that I did to update from v1.00 to v1.10 but the prompt never comes. The camera just turns on as if the .bin file isn't there. Idk... tried multiple formatted cards... I'm perplexed and pissed
08-04-2016, 10:27 PM   #2
QuoteOriginally posted by cam_abyss Quote
Usually one of these is the culprit:
1. update file misplaced (should be in the root directory, i.e. outside of any folder)
2. update file not extracted
3. incorrect update downloaded (Pentax released three v1.20's yesterday)
4. update not in SD1 (also be sure to remove SD2, just in case)
5. battery not fully charged
08-04-2016, 10:38 PM   #3
cam_abyss's Avatar
1) File was in root directory (outside of "DCIM" folder)
2) extracted from .zip to .bin
3) correct update downloaded
4) tried both SD1 and SD2 with multiple cards
5) have two fully charged batteries
And 6... since I still had the v1.10 update in my download folder, when I extract the new v1.20 zip, the .bin file that was extracted was given an extra digit. Instead of being fwdc228b.bin, it was extracting as fwdc228b 2.bin. Once I removed the "_2" the update screen came up just fine.
I think Pentax needs to remember to give updates different names so that the extraction file isn't given another differentiating digit in the case that another (older) update is still sitting in your Downloads folder.
08-04-2016, 10:45 PM   #4
CypherOz's Avatar
Yes, that is annoying, you have to use the same file name every time.
I keep the previous version .zip files so I can go back if needed.
08-04-2016, 10:48 PM   #5
Noted next time someone asks! Though I guess you could still argue the file was misplaced
08-05-2016, 01:10 AM   #6
Not a Number's Avatar
QuoteOriginally posted by CypherOz Quote
There doesn't appear to be a way for the end-user to "downgrade" to a previous version.
Using one filename is probably a way to help keeping the wrong firmware for a different camera from being loaded. I had to apply four updates to the firmware on my Kindle. The fourth update wasn't even being recognized until I noticed I had downloaded the file for a different model of Kindle which had a slightly different name on the file.
08-05-2016, 07:18 AM   #7
But not the best way to do that. It wouldn't be difficult to build a code into the filename that precluded that issue, for example if the first four characters are a model number and the last two are a version code; the device's firmware update routine could still only accept appropriately-named files without a need for them all to have identical names.
camera, pentax help, photography, prompt, troubleshooting, update
Can't get the exposure meter to activate? pigtango Pentax K-1 4 05-14-2016 06:54 AM
Can't update K-r firmware from 1.00 to 1.15 ? derek45 Pentax K-r 4 07-04-2015 05:15 PM
Can't Get the Firmware Update to Work bigted Pentax K-3 15 03-15-2014 08:32 AM
Can't get to 1/180th sync speed using Cybersync Triggers on a K-x noahpurdy Pentax Camera and Field Accessories 8 03-18-2010 06:38 AM
K-x: can't get sharp pictures, I am about to give up manteiv Pentax DSLR Discussion 35 01-22-2010 12:17 PM
All times are GMT -7. The time now is 02:10 AM. | See also: NikonForums.com, part of our network of photo forums!
