Update on the repair. I took the lens apart yesterday, but couldn't fix it. It seems that the aperture mechanism is actuated by a spring. It closes by the spring, and opens up when the a lever is pushed when the aperture ring is moved. It seems that the spring should be replaced, that's my only guess, as everything looks fine. Is there any danger in using any old spring? I guess if it's too weak it won't close the aperture, so I am back to square one. If it is too strong though, I wonder if it does any damage...
