Originally posted by Just1MoreDave I use live view/manual focusing as my standard, because it eliminates a lot of variables - diopter, focus screen, AF. That leaves only a few things.
Yeah I was thinking if it eliminates a lot of problems, what could be the problem? Yeah the SR was turned off as it was on the tripod, and 2 second timer, though I've never noticed SR having an impact in Live View. ... the cars weren't running though, just had their lights on
I'm not sure if it's tungsten or not, but it's some sorta outside light that provides a lot of clean coverage and makes it easy enough to autofocus and yet using LiveView it's just either really fuzzy, or slightly fuzzy ... can't quite get a spot where it looks properly in focus.
Nahh I've been able to lock onto Toyota badges like that photo real easy before, and it was either that or the bumper and yet none of those were in focus in the photo.
The only theory I've got is that because it's gone through so many shots and a good amount of live view use, maybe the sensor just can't perform as it originally did.
Last I checked it was 60 or 80k, and it's developed quite a few hot pixels in ultra long exposures since then.
Originally posted by quh86 so does this only happen when manual focusing using LV or also through the viewfinder?
Live view manual and auto focusing. Though manual focusing through the viewfinder, maybe it just looks in focus to me and it's not actually (though my diopter was correct before and all the way to the right/negative) ... I'm going to change it slightly and see if that helps.
Autofocus otherwise is generally fine with most lenses, and I have kinda done some AF fine adjustments.
Not sure how to use catch in focus actually, and no focus peaking sadly ... you can magnify the live view display but not peaking.
