I am using the center focus point only.
Originally posted by kiwi_jono Excuse me for asking the obvious but are you using a fixed point (like centre point) when using phase detect AF rather than letting camera random points?
Also, unlike in lens VR, you will not see the effect of the SR in the viewfinder - it only effects the actual photo.
---------- Post added 08-12-16 at 02:03 AM ----------
I been testing just in AFS and using just the center focus point. What I think is weird, is the focus in live view gets pretty sharp in the focus point, with the eyeview gets soft, and focus a little bit in the back. Also the fine ajustment I don't notice any difference in the focus accuracy, if is -10 or +10 is equal (off course this a example, I have been testing smaller steps). I have the last firmware, but I am thinking maybe something went wrong, and maybe I will give a try in 1.15, and check if there is any diference in the AF and in the fine ajustment.
About different lens the problem is the same, the zoom 35-135 or the prime 50mm.
Originally posted by bm75 AF fine tuning could be tricky and dangerous if you don't exactly know what to do. before doing that, try 1 - factory reset of all settings; 2n - check for firmware , eventually make an update to the latest version; 3 - make some tests in good light with the camera on a tripod (try another af lens, different from the 18-55 to see if something changes). after that, if you don't notice a different behaviour in the camera, try the AF fine tune. My experience with K5 is that you need some learning curve to be AF confident . I mostly use center point only , AFS and for critical situation in landscape I check the focusing with liveview magnification. Also remember that AF performance varies due to lens-body combo . I've experienced that AF is quite reliable in center point af in AFS but algorithms for AFC or Auto 11 points are not that reliable.
