08-12-2016, 01:28 AM   #1
Curious as to why the K20D does and the K-5 does not?
Having a K mount manual lens with a black anodised mount means some work on the mount or some conductive foil strategically placed to enable green button stop down metering on a K-5 (and others) but no problem on the K20D (and earlier?).
I have looked in previous threads and found the suggestion that having video on one of the later cameras might be the culprit.
Can anyone add to this or provide another reason?
Apologies if this has already been covered and I did not find it.
08-12-2016, 03:17 AM   #2
i_trax's Avatar
You are actually right!
I thought that with all black anodised lenses you would need to use aluminium foil, not true!
My K10D works fine without it, all later no go, why?
we should have menu setting to go
around it
08-12-2016, 04:43 AM   #3
QuoteOriginally posted by i_trax Quote
around it
How exactly would this work?
08-12-2016, 08:20 AM   #4
Had to dig deep into my pile of lenses to find the only black K mount lens. Green button stop down metering didn't work on either K20D or K5.
Stop Press: Gave the anodised aluminium a good clean and yes, green button stop down metering does work with K20D!
08-12-2016, 08:54 AM   #5
Otis Memorial Pentaxian
QuoteOriginally posted by Skodadriver Quote
Things change and even back in the day, there was variation between Pentax models in regards to non-conductive mounts.
08-12-2016, 08:58 AM   #6
paulh's Avatar
Just to muddy the waters a bit - I have a Vivitar (Cosina) 135/2.8 with the black anodized mount. Green button metering has always worked on my older bodies (*ist D and K10D). However focus confirmation has never worked with any of them. I haven't tried it on my K-5 yet.
08-12-2016, 12:44 PM   #7
Not a Number's Avatar
Behavior due to conductive or non-conductive mounts seems primarily linked to the body. Seems like nearly all bodies or at least with bodies with firmware released past a certain date need conductive mounts for the green button to work. My thought is the intention is to not actuate the stop down lever mechanism when no lens is mounted or when a screw-mount lens is installed.
When a non-conducting lens is mounted does the green button do nothing when pressed? Or does it meter through the lens and set the shutter speed without actuating the lever?
08-12-2016, 11:57 PM   #8
i_trax's Avatar
QuoteOriginally posted by Giklab Quote
A mechanical switch would be the way to go
camera, k-5, k20d, mount, pentax help, photography, troubleshooting
The K-1 does the 24H of Spa and kids at play kyukyu Pentax K-1 7 08-24-2016 08:17 PM
K-5 with old manual lens does not want to move the aperture kousalik Troubleshooting and Beginner Help 31 11-29-2014 02:58 AM
Does K3 use the same battery as the K-01? Ilovemypentax Pentax K-3 5 12-27-2013 08:16 PM
Is the Pixel war over -With the D4 at 16M, why does the K3 need to go to 24? philbaum Pentax DSLR Discussion 72 05-22-2012 03:23 PM
Why does the American President have to be born in the USA ? lesmore49 General Talk 75 07-12-2010 01:57 PM
All times are GMT -7. The time now is 07:37 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
