08-12-2016, 06:16 PM   #1
Can't Update K20D firmware
Hi,
Can someone help me? I have downloaded the K20D firmware version 1.04 and followed the instructions that came with the file. The camera will noyt update the firmware from version 1.00 to 1.04. It seems the camera doesn't recognise the file.
Help
Thanks!
08-12-2016, 06:20 PM   #2
Otis Memorial Pentaxian
photolady95's Avatar
Did you extract the .bin file and copy it to the card outside any folders?
08-12-2016, 06:24 PM   #3
QuoteOriginally posted by cbircn Quote
Hi,
Help
Thanks!
Here's the generic troubleshooting guide, chances are one of these applies to you:
  • Ensure you downloaded the correct firmware file for your camera (a K-3 II update will not work in a Pentax K-3, for example)
  • Ensure that you extracted the .BIN file out of the ZIP (the .BIN file is the only thing that the camera wants)
  • Check that the .BIN file is in the top level (root directly) of the SD card, outside of the DCIM folder
  • Ensure that the .BIN file has not been renamed
  • Check that your battery is fully charged
  • If your camera has two SD slots, the card with the update must be placed in SD1
08-12-2016, 06:25 PM   #4
pjv
pjv's Avatar
Hi cbircn. Hope this helps. Different camera but the same procedure.
08-12-2016, 06:49 PM - 1 Like   #5
Thank-you everyone! Got it now!
camera, can't update firmware, file, firmware, k20d, pentax help, photography, troubleshooting, version
Can't get K-1 to update (resolved) cam_abyss Troubleshooting and Beginner Help 6 08-05-2016 07:18 AM
GRII doesn't accept firmware update peterburge Ricoh GR 6 07-03-2016 03:59 PM
Can't update K-r firmware from 1.00 to 1.15 ? derek45 Pentax K-r 4 07-04-2015 05:15 PM
Can't Get the Firmware Update to Work bigted Pentax K-3 15 03-15-2014 08:32 AM
K20D firmware update ron256 Troubleshooting and Beginner Help 10 12-26-2011 08:01 PM
All times are GMT -7. The time now is 12:12 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
