08-14-2016, 03:48 AM   #1
Help! K-3 Pop up Flash broken
My friend's K-3's pop up Flash was broken after an accident. So can he use pop up Flash of K-5, K-7 to replace?
I know K-3, K-5, K-7 are different, I only want to know if my friend try to fix his K-3, will he be successful?
08-14-2016, 03:51 AM   #2
I guess it would depend on what actually broke. The shape of the flash assembly itself is different on the K-3, so you couldn't just reuse the part from the K-5. If it's just the bulb, though, that shouldn't be hard to replace.
I'd personally recommend that you have a service center carry out the repair, but if you can get the right parts I suppose it wouldn't be that hard to fix if you know your way around the camera.
08-14-2016, 03:54 AM   #3
LensBeginner's Avatar
Don't know about the pop-up flash, but I wouldn't try to repair flashes in general... there could be large charge capacitors and high voltages involved, it's not something you want to mess with...
08-15-2016, 09:14 PM   #4
Thank you guys. My friend contacted service and the flash could be fixed.
camera, flash, k-3, k-5, k-7, pentax help, photography, pop, troubleshooting
Can't set Pop-up flash on K-5IIs hjoseph7 Troubleshooting and Beginner Help 5 07-28-2015 09:01 PM
Broken Pop Up Flash Gerrys Troubleshooting and Beginner Help 8 04-24-2013 12:47 PM
k5 pop-up flash hook (that holds the flash down) broken... Thesorus Troubleshooting and Beginner Help 4 01-06-2011 08:34 PM
Help! KX Pop-up Flash TAP Pentax DSLR Discussion 2 05-26-2010 01:06 PM
K2000 - Pop up flash will not pop up. tkindred Pentax DSLR Discussion 6 08-17-2009 08:54 AM
All times are GMT -7. The time now is 03:49 AM. | See also: NikonForums.com, part of our network of photo forums!
