08-25-2016, 02:21 PM   #1
E-man's Avatar
How can I get the sticky residue off my rubber lens grip?
So I've got this Sigma UC 70-210mm AF zoom lens and it's in great shape except the rubber grip has this sticky residue on it. It's not dirty but it just feels yucky like a three-year-old kid has been handling the lens after eating a peanut butter and jelly sandwich. I think the rubber is actually beginning to deteriorate. Is there any way to clean it off? I tried using an alcohol prep pad, since isopropyl alcohol is a reasonably good solvent that evaporates quickly and leaves no residue but that didn't seem to touch it. I really don't want to use anything that might work its way inside the lens and gum up the works. Suggestions are greatly appreciated.
08-25-2016, 02:42 PM   #2
BigDave's Avatar
I would try a little Goo Gone, available everywhere. Put a bit on a cotton swab and work a small area to see if A- it cleans off the stickies (it should, nicely), B- It doesn't deteriorate the rubber grip!
Regards,
08-25-2016, 02:44 PM   #3
csa
csa's Avatar
I would suggest a dab of Avon Skin So Soft oil on a cotton swab; it won't harm the rubber, & I've removed sticky residue with it. Of course Avon doesn't suggest this use!
08-25-2016, 02:52 PM   #4
ramseybuckeye's Avatar
Plus one for the Goo Gone
08-25-2016, 07:11 PM   #5
Limonene
I think Limonene would do it have used it for this purpose. It is also very good for removing sticky label residue from any surfaces.
08-25-2016, 07:16 PM   #6
Otis Memorial Pentaxian
Mild detergent in water?
08-25-2016, 08:55 PM   #7
UncleVanya's Avatar
I have read somewhere that a certain vintage of Sigma's just does that. It is not coming off because the rubber is deteriorating as you surmised. I suspect you would have to replace the rubber to really resolve the problem.
08-25-2016, 09:12 PM   #8
Mark2100's Avatar
I got the same lens in an auction lot the other day, with the same problem. Since it was basically a free lens, I soaked a couple of paper towels with 91% isopropyl alcohol and went to town. It turned the towels black. So about 8 soaked towels later, the black stopped coming off, and no more sticky on the lens. I was careful not to get any alcohol inside the lens, but not careful enough to not wipe off most of the ft/meter scale, which I can no longer read. A fair trade though imo. It is a sharp little lens, but seriously doubt I'll be pulling out any flash and need to know distance.
08-25-2016, 09:54 PM   #9
Alex645's Avatar
The main culprit to this problem is DEET found on mosquito repellent. It dissolves the material at a molecular level. At best, a lot of ʻelbow greaseʻ with the Goo Gone mentioned by others and tons of patience. For anyone needing mosquito repellent, I highly recommend Picaridin based mosquito repellent. It is less toxic but effective enough and doesnʻt mess up plastic and rubberized surfaces.
08-25-2016, 10:20 PM   #10
I second the use of ethanol or isopranol plus elbox grease. I have a Sigma with this "feature" back from the film days. Disgusting. Sticking glue everywhere. I got it off, however. Most probably, you cant avoid rubbing of the meter / feet scale. Since it is a pretty standard zoom in my case (not fast, not wide enough for my current taste), I dont use it anymore. Moreover, I probably wont buy Sigma ever again, although I know they changed the formula.
08-25-2016, 10:28 PM   #11
Mark2100's Avatar
Goo Gone instructions warn not to use on rubber.
08-26-2016, 03:03 AM   #12
Whiteboard cleaner.
08-26-2016, 09:54 AM   #13
I have had problems with old rubber going soft and sticky, not just lens grips, but satellite decoder remotes, and the sponge rubber in measuring instrument cases. My Pentax ME super's light seals turned to sticky goo, just as well they can be replaced.
As for lens grips, a less loved donor lens with good rubber would be my fix.
08-26-2016, 02:16 PM   #14
BigDave's Avatar
Another option, accessory lens grips, check out this e-bay link
Lens creep solution | eBay
08-26-2016, 02:49 PM   #15
They sell some wipes in the automotive department usually some orange scent or something. Bucket of scrubs is what mine calls them. I do auto glass and this is the only thing that cleans up the glue I use. If there is something around the house that need scrubbed, it is the first thing I grab. They work awesome. I've seen them in walmart. Made for cleaning hands so no gloves needed. Here's amazon link. https://www.amazon.com/gp/product/B000BYE9RK/ref=s9_dcacsd_bhz_bw_c_x_1
alcohol, camera, lens, pentax help, photography, residue, rubber, rubber lens, sticky, troubleshooting
How can I, or can the administrator delete my account. RedSky Site Suggestions and Help 3 06-09-2016 03:11 PM
HELP I can't get my 50 off my macro teleconverter! shaolen Troubleshooting and Beginner Help 2 07-21-2012 09:20 PM
how much can i get for my k-r ? arsenal_emyrates Pentax K-r 6 04-26-2011 01:32 AM
[Afraid] Can't get my M42 screw mount lens off my K-x! tiny Pentax DSLR Discussion 11 10-28-2009 10:25 PM
How can I get good results from my K100D? zoomzoomfan Photographic Technique 42 12-01-2007 10:40 AM
All times are GMT -7. The time now is 02:45 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
