09-01-2016, 07:54 AM   #1
How to take B&W pictures with Pentax K-r
I am new to this camera. Can anyone advise me on how to set up the K-r camera for B&W photography?
Thanks.
09-01-2016, 07:59 AM   #2
One of the custom image settings is monochrome IIRC, but as I'm sure many others will suggest, shooting in raw and tweaking the results in Lightroom would give you greater control....
09-01-2016, 08:01 AM   #3
Digital filter - monochrome. P255, user manual.
09-01-2016, 08:49 AM - 2 Likes   #4
Turn the camera on. You'll probably see something similar to this on the rear screen.
Press the info button on the rear of the camera. The screen will change to this. The icon in the upper left may not show BW but that is the icon you want highlighted in green as shown.
If the icon in the upper left in not highlighted in green as this image shows, use the wb or iso buttons to highlight that icon. The second line above that icon will tell you what mode the camera is in. (In this case, it is monochrome.) Once that icon is highlighted in green press the OK button. This screen will appear.
The shooting mode now appears in the upper right corner. Use the wb or iso buttons to change the mode. When you have the mode you want selected press the ok button and then press the info button.
09-01-2016, 12:33 PM   #5
With all you guidance I found the monochrome setting! It seems pretty simple, once you know how. Thanks for your help!
09-01-2016, 01:37 PM - 1 Like   #6
Paul the Sunman's Avatar
All very well, but to reiterate what robthebloke said, you will get much better results by shooting RAW and then choosing your B&W settings in postprocessing. For example, that gives you the option of selecting red, green, yellow, ... digital filters to get very different results.
camera, k-r, pentax help, photography, pictures with pentax, troubleshooting
How to shoot B&W on K-5 LeroyPK Pentax K-5 & K-5 II 13 03-09-2016 03:43 PM
Architecture B&W Torv - how to make it better? ps1984 Photo Critique 8 10-26-2015 03:25 PM
My experience with the Pentax k-30 @ B&H (BIG PICTURES) JinDesu Pentax DSLR Discussion 19 02-24-2013 11:26 PM
how to take multiple shots in self timer with pentax k-r JaneDoe08 Troubleshooting and Beginner Help 6 12-28-2011 06:42 PM
How to take pictures of lightening with K10D mahukey Photographic Technique 7 07-24-2010 03:11 PM
All times are GMT -7. The time now is 02:13 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
