09-06-2016, 02:52 PM   #1
Battery issue
I have a K-5, great camera, use a lot and have two Pentax rechargeable DLI90 batteries that I've used since 2011. I have one in my attached battery grip, the other in the body. This way when one runs out, the other is ready to go.
The other night I noted that one battery would only charge (green light) showing for a couple of minutes then the green light would go off. I tried a number of times, including taking the battery out of the charger and reinstalling . Same pattern...green charging light on....then off.
As it happened my other K-5 battery had run out of power, so I put it on the charger. Green charging light remained on for some hours, eventually went out and battery was fully charged. Charger and second battery performed charging as they always have in the past. Normal.
As a result, I'm guessing that the first battery will no longer take a charge. Correct or do you think there is an issue with the charger ?
Me, myself, I'm fairly sure it's that the first battery will not hold a charge and that the charger is ok as it fully charges the second battery. But in case I'm missing something, could it be something else, before I order a new DLI90 battery ?
I believe that the Pentax DLI90 battery is the specified battery for the K1. Good, as if I ever get a K-1, I will have a spare battery.
What are your thoughts on my battery....or possibly charger issue ?
09-06-2016, 02:57 PM   #2
photolady95's Avatar
Location: Cruising PentaxForums and watching your back.
On the first battery I would try cleaning the contacts on it with a pencil eraser, brushing the contacts free of any eraser bits before attempting another charging session. Sometimes cleaning them causes better contact.
09-06-2016, 03:06 PM   #3
jatrax's Avatar
QuoteOriginally posted by lesmore49 Quote
Have you tried this battery in the camera to see if it was actually discharged? A short period and then shut off could also mean the battery was already charged when you put it in the charger.
If it shows as depleted in the camera then try @Photolady95 suggestion and if that doesn't work I would say, time for a new battery. Not sure what the actual lifespan of these batteries is, but it is not infinite.
09-06-2016, 03:43 PM   #4
measure the voltages (between the + and - contacts); this should give you an indication of whether the battery is charged or not.
---------- Post added 09-06-16 at 03:44 PM ----------
if both are good they should show same voltage
09-06-2016, 04:11 PM   #5
ramseybuckeye's Avatar
They do wear out, and not necessarily at the same time.
09-06-2016, 04:20 PM   #6
Thank you for your excellent suggestions. I will try those steps. Again thank you for your common sense advice.
09-06-2016, 06:22 PM   #7
Make sure the battery is inserted correctly into the charger and that the contacts are clean. Pentax batteries that I have had have not given up after years of use.
09-07-2016, 02:20 AM   #8
Same thing happened to me just now. One of 5 or 6 D-Li90 batteries I have. Though its not the Pentax brand, it's Pearstone. Fairly sure its time to send it to recycling. All other batteries OK. It shows fully charged but goes flat very quickly after using in camera.
After a couple of minutes or less the camera stops working and a voltage check of the battery shows zero charge. Battery now in the recycling bin.
battery, camera, charge, charger, dli90, issue, k-5, light, pentax, pentax help, photography, troubleshooting
Battery Issue Long Exposure K5II dougfrey Pentax K-5 2 09-07-2015 06:17 PM
Is battery longevity an issue with the 6x7? cooltouch Pentax Medium Format 27 12-12-2014 11:20 AM
K2000 Battery Issue K2000Shooter Troubleshooting and Beginner Help 9 03-10-2012 11:44 AM
Pentax K5 Battery Issue blitzping Pentax K-5 3 02-18-2011 10:46 PM
K100D battery issue Pierrot Pentax DSLR Discussion 22 04-04-2007 10:04 AM
All times are GMT -7. The time now is 10:08 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
