09-10-2016, 03:02 PM   #16
mee
I wouldn't try updating the firmware until your camera is stable enough to stay on for at least 10 minutes straight. If the camera shuts off in the middle, you could potentially brick the camera (game over).
Please note there is a battery saving feature/setting that will turn it 'off' after a certain amount of idle time (not taking photos, not going through the menus, not reviewing photos, etc) so please keep that in mind.
I don't have a K-x anymore (started with one - neat camera) but I do have a very similar K-r. I see on menu screen 3 of the config (wrench icon) there is the 'Auto Power Off' setting which is selectable (defaults to 10 minutes but can be set as low as 1 minute). There is also a setting to identify which type of battery used (Lithium, Nickel-Metal Hydrive, Alkaline, or Auto-detect). I'd set that specifically to the battery type you're using if Auto-detect seems ot be giving an issue. Though generally I think that setting is used to gauge battery life (how much battery left) over anything else. Still, I'd set it to the correct value.
09-10-2016, 05:29 PM   #17
CP140's Avatar
QuoteOriginally posted by katie_m Quote
Ok, will do! I'll keep you posted, once I've had a chance to pick up a charger. Fingers crossed!!
There are a couple types of disposable lithium AA batteries out there. I had good luck with the Energizer Ultimate Lithium batteries (silver wrapper with a blue stripe) in my K-30, but didn't have much luck with a cheaper set of disposable lithium AAs... the cheaper ones didn't seem to have enough juice to power the camera for very long.
As for pre-charged rechargeable batteries... they tend to slowly drain over time. Unless you got a really fresh set, they may have already reached the point of needing to be charged. Modern digital devices are very sensitive to under-voltage power supplies and it doesn't take much for a battery to drop below that "magic" voltage particularly when you start pulling power out of it.
09-11-2016, 12:46 PM   #18
Energizer make the Ultimate Lithium and a cheaper version with less capacity. A battery tester or multimeter with battery testing facility would be a good idea.
09-11-2016, 01:12 PM   #19
dms
(About using lesser versions of Lithium AA's
As I mentioned my K-x has similar problem and I use/used Energizer Ultimate Lithium battery.
Nevertheless likely all Lithium non-rechargeable AA's have the same voltage.
09-11-2016, 07:06 PM   #20
CP140's Avatar
QuoteOriginally posted by dms Quote
Yep... all the same voltage when not under load... but when you start sucking power out of them, cheaper batteries with less capacity may experience more of a voltage drop (like all batteries do) than the higher capacity version... and under voltage makes electronics very grumpy!
09-12-2016, 04:48 PM - 1 Like   #21
Thank you again, everyone, for your help! I charged my "precharged" batteries (they did indeed need some extra juicing), successfully updated the firmware, and changed the type of battery on the camera, and that seems to have done the trick! Now it's time for me to REALLY fool around and teach myself how to operate it. Thank you, thank you, thank you! I am so very grateful for all of your help.
09-12-2016, 06:03 PM   #22
paulh's Avatar
Great news - now go out and have fun
09-12-2016, 10:02 PM   #23
CP140's Avatar
Very good news indeed!
09-12-2016, 10:23 PM   #24
sergysergy's Avatar
great. have fun. the little K-x was my first DSRL. I loved it.
batteries, battery, camera, k-x, kx, lithium batteries, pentax help, photography, troubleshooting
Working with the K-x (or even the K-5) DRabbit Video and Pentax HDSLRs 6 02-21-2011 04:14 AM
For Sale - Sold: Mint K-x with lens/12 batteries/box/accessories $425 (CONUS) treebeard Sold Items 2 02-14-2011 03:26 PM
Experience with NiZn batteries and K-x? causey Pentax Camera and Field Accessories 4 09-15-2010 09:12 AM
K200D battery symbol in LCD flashes, even with good batteries jaytaz Pentax DSLR Discussion 10 09-01-2010 03:31 AM
possible problem with my new K-x (other than batteries) davidvcd Troubleshooting and Beginner Help 13 11-12-2009 03:43 PM
All times are GMT -7. The time now is 12:35 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
