Originally posted by teleioo2002 . when i rotate the front or back e-dials either direction it lets me change the aperture, but can't for the life of me to the shutter speed setting. what am i doing wrong there?
You will need to set the e-dials to your settings for " P " mode. The 1st small image shows the menu page you need. The picture is showing button customization, but you want the 1 above which is e-Dial programming. The top left of the 3 pictures shows the line you need for programming " P." Highlight P Tv Av P and touch the right button on the 4 way controller, and the setting options appear. I have mine set as shown, when in P mode, rear e-Dial does aperture, and front dial does shutter speed. Try this and if you still have problems, post again. Good luck.
EDIT - Page 71 in your manual.
