As DeadJohn says, internal battery that retains parameters in memory has died, or is just showing its age.
Do you normally leave the camera with the main battery in place? If not, you could try leaving the (fully charged) main battery in place for a few days as it will then charge the internal battery, assuming the internal battery is ok. Set the time/date.
If after a few days you remove the main battery, etc, and the date resets then the internal battery is definitely no longer servable. It will probably cost more than the body is worth to get it fixed I'm afraid, so either good time for an upgrade or just live with the problem.
