Originally posted by Aslyfox Thanks for the quick responses and for laughing so quietly
Actually between the time I posted my question and now I discovered the area of the forum that I needed to be reading
So moderator the choice is yours, I'm ok with deleting this thread or if you think that others would be aided by my "stupid question" leave it up
I've learned that I need to just "go with the flow" and not to worry about it
Once again thanks to all
Not to worry dude, I had my *ist for 3 years, before I even found out it wasn't 35mm. I just assumed, it's a Pentax digital, it's about the size of my Program Plus.... I wondered why my FA 50 1.7 seemed to be longer than before.
But go with the flow works for me. Look through the view finder, what do you see, want wider, get a wider lens, want longer, get a longer lens, or just forget the whole thing and get an 18-135. The whole idea of one sensor 36x24 being some kind of true sensor and anything smaller being a "crop" sensor is just complete photo enthusiast hogwash.
It did get started in film days when most DSLRs were FF and some manufacturers started coming out with "hafl frame" cameras. And thanks to the movie industry at some point 35mm negs started being called frames. But in the current context, with so many great cameras made in so many different formats, picking 36x24 to be called "full frame" is disingenuous. It really is just marketing hype, and enthusiast "my camera is better than yours" nonsense.
The difference between film and digital would be that on digital you can completely reproduce exactly the same image with different formats and the same resolution 70%-95% of the time. IN film you had a smaller negative with associated limits to enlargement. In digital the DNG file will be the same size and enlargement possibilities will be the same.
An image taken with a 1 inch Panasonic FZ1000 taken at 100 ISO will be functionally the same as the same image taken with a 24 MP APS-c or 24 MP 35x24. The digital negative in many situations doesn't really care what format was used to capture the image. although people will argue until they are blue in the face against that.
There's still folks that are so locked into film thinking, they think you can enlarge a 12 MP 35x24image, more than you can enlarge a 24MP 1 inch sensor image. This kind of thinking is still being passed down from old film guys to guys who have only shot digital.
