I recently picked up a good condition Takumar 300mm f4 screw mount lens (the original 3-element version). I'm using a genuine Pentax M42 to K mount adapter, but when I screw the lens in, the adapter doesn't lock into the camera. Specifically, the focusing ring is slightly stiff on the lens (but not stuck) and simply adjusting the focus can unseat the adapter (which can cause the lens to separate from the camera body, with a potential for disaster).
The adapter sticks to the lens and takes significant effort to remove manually (or I can remove it easily by simply attaching it to my k1000, where the adapter seats properly and pulls it right off the lens as easily as I'd expect).
I didn't anticipate this problem at all, as the adapter works perfectly with my Takumar 50 f1.4. It remains locked into the K-3 or K-01 exactly as I'd expect, and I unscrew the lens before removing the adapter.
I've tried mounting the adapter to the lens first, and to the camera body first. Either way, it sticks to the Takumar 300mm lens's threads and unseats from the mount without much in the way of resistance. I do hear/feel two very faint clicks as it unseats, which I think might be the locking pin moving over the screw holes on the back of the mount.
The most perplexing thing is that it works so well on the K1000, but not the K-3 or K-01. Anyone else encounter a similar problem? Any suggestions?
