09-19-2016, 02:04 AM   #1
WhiteBalance mismatch when shifting from manual to Automatic (green) control
Hi Folks - Please help a beginner..
My K3 Pentax is 2 years old and have worked perfect so far. A new error has occured: When I take pics on Automatic (green), - pics er perfect and WhiteBalance (on AWB) also Works fine. However - on manuel setting (M, Sv, Tv Av) something goes wrong with WhiteBalance. Pics turns red, green, violet .... and it appears that WB/AWB is not able to Work at all. Is this an error in the sensor - or is i possible to correct the error with new or adjustede software. There is no "mismatch" or error indikation on screen.
Kind regards : VincentD - Verner Lynge
09-19-2016, 03:09 AM   #2
Ole
Ole's Avatar
Please check the custom image setting. If set to Cross Processing or some other funky setting you may get unexpected results. The default setting is Bright.
If all else fails, reset the camera to its factory settings in the Setup menu.
09-19-2016, 03:54 AM   #3
Na Horuk's Avatar
Yes, press Info or check the manual, and look for the Jpeg mode, Custom image settings, Cross processing, Digital filter (I'm not sure exactly what the names of these options are on your camera). These options can change the colours of your photos, sometimes subtle, sometimes big changes. I think there are three options that can affect the colours.
Factory reset is a good idea, but do it only after you tried everything else. You can also try updating the Firmware. This can sometimes cure a little hiccup. There are numerous threads and blog posts and even a youtube video about the firmware update, if you want to try.
Also, you can upload a photo or two, so that we can see the problem. Maybe then someone will have more ideas. We have had cases in the past where photos became all neon pink, and if I remember right those were caused by faulty SD card writing. Was a card problem. In worst case scenario, it could also be a sensor problem, but check everything else first. SD card or sensor problem is unlikely in this case, because it works correctly sometimes
09-19-2016, 11:49 AM   #4
Fixed - thanx for your help
Thankyou Guys
Tried your suggest - but in the end a reset was the best solution. I took a while to find all my settings Again - but now it Works fine Again. Never found out what the WRONG setting was - or just an error in the sensorSW - but reset and restart.
Again thanx for your help.
VincentD
camera, error, k3, pentax help, photography, pics, troubleshooting, white balance, whitebalance, whitebalance mismatch
Helios 44M-4 Modification - From Automatic only to fully Manual Helios 1984 Maintenance and Repair Articles 1 03-12-2016 08:38 PM
Epson printers - dumb question about shifting from PK to MK ink frogoutofwater Digital Processing, Software, and Printing 5 10-28-2015 01:13 PM
DA 35mm Limited - Shifting viewfinder image in Manual Focus c.a.m Pentax SLR Lens Discussion 4 04-07-2015 06:22 PM
Manual control lost when popup flash is open gathomas72 Troubleshooting and Beginner Help 8 10-30-2013 11:00 PM
Fujinon 55mm f1.8 - Surgery to change from AUTOMATIC to manual Pepe Guitarra Troubleshooting and Beginner Help 14 01-28-2012 07:33 PM
All times are GMT -7. The time now is 09:36 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
