Originally posted by Tish99 As far as I can tell both my lenses are properly mounted and I am having the same problems with both. I have tried using AV and F4.5. If I take a picture of the bright sunlit window I can see this in playback. Anything else is now completely black since I did the camera reset, so no more bright lime green areas.
---------- Post added 09-22-16 at 08:57 AM ----------
No - everything looks fine through the viewfinder. It is the playback of photos and downloading them where they are all pretty much black
---------- Post added 09-22-16 at 08:58 AM ----------
How would I do this?
To check for the sticky aperture unmount the lens and move the aperture lever on it with your finger. Tre aperture should open and close rapidly.
To check for the aperture block failure you should use the lens that allow you to set aperture manually on the lens, not in camera using dial. If you will set e.g. f4, tre aperture will stop closing at this value. So you should get notmally exposed picture.
