09-25-2016, 07:14 AM   #1
Faulty screen on K-x
Have just received a K-x I won on Ebay. I am unable to get any display on the screen . Have studied the manual and canít see any way it can be turned off , so am asuuming it is faulty. Would appreciate comfirmation or otherwise from someone who knows the camera before I send it back. Pity as Iím very pleased with the pictures Iíve taken with it tyia, Regards , Mike
09-25-2016, 08:48 AM   #2
BigMackCam's Avatar
Mike - have you tried pressing the INFO button (once, and if that doesn't work, twice)?
I'm not sure, but this may help:
https://www.dpreview.com/forums/thread/2707042
09-25-2016, 09:40 AM   #3
Audi 5 cyl's Avatar
As I have this camera and as it ended up on the floor several times, I can only say that the connector that takes the flex cable from the whole rear panel on the k-x is very easy to detach. It detached once when manipulating the camera with a heavy lens attached (Pentacon 4/300, 2,2kg).
I've opened my camera to attach this flex cable at least 5 times, last time i super-glued it in place, since then no problems, even though my daughter recently pulled it of the table on the tiles.
If you have the same issue, the light on the rear panel won't turn on when inserting sd card and the screen does not work at all. Also, if you have tools to measure the voltage on the battery, you will see that nothing is happening when pressing buttons on the rear panel. If it is just a dead screen, I've been seeing it online for as little as 16 euros.
If it is the connector issue, the repair will require that you take off the bottom, top and rear panels off, in order to reach the connector. The same stands for the screen replacement.
09-26-2016, 02:16 AM   #4
Many thanks for your replies. I have tried the various buttons as suggested and the screen still has no display. So will return it and try again.Although it takes very good photos I'm not sure that I like it. Lack of focus light and top LCD being the main reasons (I have a K100D). So may try a different model or stay as I am for now.
Thanks again , Mike
camera, faulty screen, k-x, pentax help, photography, screen, troubleshooting
Faulty K-x? greatwatermelon Troubleshooting and Beginner Help 6 01-01-2012 03:23 AM
K-x Battery Level Indicator - Faulty? Rik Rabbit Pentax DSLR Discussion 11 01-03-2011 10:02 AM
Focus Screen on K-x Pentax Bob Pentax DSLR Discussion 8 12-17-2010 03:49 AM
K-x delay in showing picture on screen TeeDub Pentax DSLR Discussion 6 05-03-2010 05:54 AM
Faulty equipment or faulty photographer? (K-x) mamba909 Pentax DSLR Discussion 22 02-15-2010 12:16 PM
All times are GMT -7. The time now is 12:07 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
