09-25-2016, 12:14 PM   #1
Memory Card Error
Hello,
I have a Pentax, I believe the model is st DL? Anyways, I bought a new SD card, 4GB the original was 2GB. I put it inside my camera and it just says 'memory card error' and when I try to format the card on the system it says memory card error once more. How do I fix this?
09-25-2016, 12:45 PM   #2
Alex645's Avatar
The *ist DL was released in 2005, it was designed to use the standard SD memory cards 256MB, 512MB, 1GB and 2GB options, as that was sufficient for a 6MP sensor.
Transcend 2GB SD Memory Card TS2GSDC B&H Photo Video
I suspect your camera canʻt use a newer 4GB card unless there was a firmware update to do so.
09-25-2016, 01:58 PM   #3
I recall having to update the firmware on the *istDS in order to use 4Gb cards.
09-25-2016, 03:13 PM   #4
There are some 4Gb SD cards out there, but chances are yours is SDHC, so you'd need to update the firmware (using a standard SD card) for the 4Gb SDHC card to work.
The 2Gb card should do the trick.
Here's the firmware update download page:
Software Downloads : Support & Service | RICOH IMAGING
And here are some troubleshooting tips in case you run in to issues:
Pentax Firmware Update Guide - Tutorial Videos | PentaxForums.com
camera, card, error, memory, memory card, pentax help, photography, troubleshooting
K3 + flu card "memory card error" (both new) rburgoss Troubleshooting and Beginner Help 28 02-10-2015 01:16 PM
Memory Card Error Doggai Troubleshooting and Beginner Help 3 08-14-2014 04:34 PM
Memory card error notice Tommy Armstrong Visitors' Center 3 09-09-2012 09:50 PM
memory card error problem cdm807 Troubleshooting and Beginner Help 15 10-17-2009 07:22 PM
Memory Card Error on k100d _mouse_ Pentax DSLR Discussion 8 04-25-2009 09:02 PM
All times are GMT -7. The time now is 07:39 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
