09-27-2016, 02:06 PM   #1
What is the dark border on the petal on the right?
D70 body with AF70~210mm 1:4~5.6 non D lens. 1/30s, f/4.8, ISO 200, no flash, Focal Length 145mm and used CWA Metering.
I would like to know the cause of the black or dark border on the petal to the right. I have never seen this type of artifact and will appreciate the assistance.
Many thanks,
Tony
I have also spotted a dark border on the petal to the left on the same flower. I wonder if it is some sort of CA caused by a contrasty background.
Cheers.
Read more: What is the cause of the black border of the petal on the far right? - Technical Troubleshooting - NikonForums.com
09-27-2016, 02:11 PM   #2
Nass's Avatar
Do you have the full size original anywhere (or even better the RAW original full size?) I'm thinking some form of dramatic posterisation caused by sharpening a cropped edge together. Normally I see this when flash is used - flash ghosting - but no mixed light here so it's a bit of a mystery (interesting)
09-27-2016, 02:25 PM   #3
Senior Moderator
Parallax's Avatar
I suspect it's sharpening artifact.
This can happen when you sharpen a full size image and then reduce its size.
Try processing the image exactly as you did except for the sharpening step then reduce it to its current size and see if the artifact is still there.
09-27-2016, 02:27 PM   #4
Nass's Avatar
^^ that. +1. My thought too
09-27-2016, 02:37 PM   #5
Alex645's Avatar
I agree with all above. In Photoshop this could be from too much Unsharp Mask, or more likely from a High Pass filter that is overlay on the previous layer. Bottom line is too much sharpening in post processing.
09-27-2016, 02:59 PM - 1 Like   #6
Interesting that the flower on top has the beginning of a black or dark border on the petal to the right also. However, it does not appear to have been in the sharpening field. The original has the artifact as I had saved it that way numerous times. Strange how I did not notice it at first. Oh well. lesson learned. Listen, I genuinely appreciate all the helpful comments. Another issue to baby sit in my digital photography.
Many thanks,
Antonio
09-27-2016, 03:08 PM - 1 Like   #7
BigMackCam's Avatar
Hi Antonio. It looks very much like an artefact of the in-camera JPEG processing engine. Could be a combination of aberration (or aberration correction) and sharpening that's exacerbating the problem.
You might want to read the following old thread of mine. I was experiencing similar problems, and was never able to fully avoid this type of artefact in some JPEG shots using older lenses, regardless of settings. It's one of several things that pushed me towards shooting in RAW and developing my JPEGs in post-processing software. Pentax in-camera JPEG processing isn't the best, I'm afraid.
https://www.pentaxforums.com/forums/172-pentax-k-3/291975-dark-edge-outline-photos.html
09-27-2016, 04:54 PM   #8
I did delete the original upload because of all the issues it had. I found an original in Photo Editor 10 that did not have any problems except what appeared to be a little discoloring on the petals, which may be the result of aging. However, to be sure I did increase blur by two clicks, and even though it suffered minimal damage to sharpness, it appears to have survived very well. Please see my new upload. Well, many thanks to all who so generously gave of their time and knowledge.
Rgds,
Antonio
09-27-2016, 09:09 PM   #9
I think JPG compression artifact or over-sharpening. Click on the image in the link and look at the background leaves. I see a lot of pixellation in the background color transitions, too.
09-27-2016, 11:56 PM   #10
This was taken with my Nikon equipment. I normally get very good results with the AFNikkor 70~210mm non D lens. I do not know what happened here. Anyway it has been deleted and replaced with the second copy. Speaking for myself only, I normally take two photos of a subject I really like, just in case something like this happens.
Many thanks,
Tony
09-28-2016, 12:01 AM   #11
BigMackCam's Avatar
QuoteOriginally posted by Tonytee Quote
Interesting. Well, as you've seen from the thread link I provided, I got a very similar result shooting JPEG with older lenses on my Pentax bodies. I still believe the issue is a combination of aberration (and/or aberration correction) and sharpening in the JPEG engine - and shooting RAW is the best way to avoid this, as you have complete control over the processing (just as if you were using your own darkroom with film).
09-28-2016, 12:22 AM   #12
I just had a thought. Looking at the new photo uploaded, I do see some faint brown color where the dark border was. I wonder if that is the nature of the flower when it is leaving this earth, and the taking of the photo in the first shot created a real monster by darkening it further. I shoot mainly flowers, so I have never seen black or dark bordering like this before. Tomorrow I will return to my neighbor's garden and take the same shots again with the same equipment and see what happens. We are to have a very sunny day so it will be interesting. I will keep you posted.
Gratefully,
Tony
border, camera, cause, dark, pentax help, photography, troubleshooting, what
Question My "For Sale" item expired. What is the length of time an ad is allowed on the site? TKB Site Suggestions and Help 3 02-06-2016 03:31 PM
What is the 'silver' on the silver K-3?? fstop18 Pentax K-3 & K-3 II 5 10-14-2015 04:31 PM
On a k3 how to you get the top to light up so you can see the info in the dark pentaxk3user Troubleshooting and Beginner Help 3 09-27-2015 04:24 AM
What's the difference between the petal lens hoods and the round ones? ZombieArmy Pentax SLR Lens Discussion 35 08-19-2015 03:01 AM
The way it is on the Right normhead General Talk 4 07-03-2012 11:34 PM
All times are GMT -7. The time now is 02:41 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
