09-29-2016, 11:27 AM   #1
ivanvernon's Avatar
DA lens aperture on MZ-S
I would like to know how to use manual mode (M) with MZ-S camera when the lens does not have an A ring. With MZ-S you go into M mode by setting the A ring to a specific aperture instead of the A position. I could not figure this out with the Pentax-DA 50mm f 1.8, so switched to the Pentax-D FA 50mm f 2,.8 macro, and it works fine. I am assuming that DA lenses that lack an A ring are simply not backwardly compatible with the MZ-S except in Green/Automatic mode.
Comments from knowledgeable persons will be appreciated.
09-29-2016, 11:42 AM   #2
Correct, you can use P or shutter priority, but not aperture priority since there's no way to dial in the aperture via the camera. The camera should show you the aperture value in the viewfinder, though, so you can try to hint at it with the shutter speed.
If you're looking for a film body that lets you control the aperture like a DSLR, try the PZ-1 /Z-1.
09-29-2016, 01:32 PM   #3
UncleVanya's Avatar
I know of a pz-1 for sale off forum from a friend if anyone is interested. He is seriously underpricing it. Pm if curious.
I personally love love love the pz-1.
09-29-2016, 02:59 PM   #4
ivanvernon's Avatar
Thanks Adam, appreciate your confirmation of what I supposed was the case. I do have a nice PZ-1P camera, so can use my crippled DA lenses with it. I did confirm, using the DA 50 with the MZ-S that the DA is full-frame compatible, no news to anyone else, I suppose.
---------- Post added 09-29-16 at 06:01 PM ----------
Thanks for the tip. Actually, I have a very nice PZ-1P, and will give it try with the DA 50. I believe the PZ-1P is almost the same as the earlier PZ-1. It is a little odd how much lower the PZ-1 is priced than the MZ-S.
09-29-2016, 04:06 PM   #5
MadMathMind's Avatar
This is what I do. I dial in the shutter speed until it hits the aperture I want. It's not ideal but it's really not bad at all, since film makes you stop and think a bit anyway. You can afford a couple more seconds fuddling with the camera because you're already being methodical, away from the spray and pray of digital.
09-29-2016, 06:28 PM   #6
foto guy's Avatar
I've used the DA40 on my MZ-S many times and it works great! As others have said, you can dial the shutter speed until it gets to the aperture you want. Yes, it's slow, but never stopped me from getting the shot I wanted.
09-30-2016, 08:30 AM   #7
The Pentax film era camera you want for 35mm full frame and robust build quality that directs all no apature ring lens from the body, (and also lets you set the apature from the ring if the lens has one) is the MZ-6 (or MZ-L if you are in north America), its a fully specified camera and the same size as your MZ-S.
09-30-2016, 01:54 PM   #8
UncleVanya's Avatar
QuoteOriginally posted by Snappertim Quote
What makes that camera better than the PZ-1/PZ-1p (Z-1/Z-1p) which was already recommended?
MZ-6 lacks center weighted metering pattern
has smaller bracket range
has much slower flash sync speed
lacks hyper program and hyper manual modes
2 fps slower
doesn't support power zoom
can't change focusing screen
lower magnifcation viewfinder (.7x vs. .8x)
weaker onboard flash GN11 vs. GN14
does not support flash exposure compensation (onboard)
uses a pentamirror vs. a pentaprism (Pentamirror is much less bright)
it does have 3 autofocus points vs. the single one on the PZ-1 series
It is lighter (400 vs. 650g)
it can have a battery grip (4xAA)
09-30-2016, 03:44 PM   #9
Er excuse me you just gave 3 of the best reasons to own one camera over another 1 Size 2 Weight 3 No weardo battery required, One thing you can allways get is an AA battery, plus a packet of English cigaretts or a can of Coke, I know this having purchased some in the valley of the Kings in Egypt and half way up mount Cook in New Zealand, that mz battery grip fg saved the day on several occation's, and made the camera a joy to use, I had the phoney do nothing FDP grip on the Z1P not the same at all.
Also having owned both cameras and not just read the spec sheet, the MZ-6 did have more focusing points and also it was about twice as fast using them, it locked on more often and in much lower light, the donkey slow Z1P focusing is the major reason its a rare camera to find.
09-30-2016, 10:54 PM   #10
UncleVanya's Avatar
Sorry but I own the pz-1 and would never give up that viewfinder for a pentamirror. I also think your memory of that non battery grip is tainted. It fits my hand so nicely. I found focusing reasonably snappy but lens selection mattered. Lastly the one point I will concede is the battery. But the pz-1 batteries lasted a long long time which was a plus. I still can't say that I used the MZ-6. But I know I never found another Pentax film camera compelling enough to retire my pz-1.
10-01-2016, 02:05 AM - 1 Like   #11
ivanvernon's Avatar
Thanks to all . . .
I appreciate all the comments, and now I am happily shooting a cheap roll of Kodak Ultramax 400 (36) on my PZ-1P. It was nice to get all the comments on various alternatives to the MZ-S, and I may pick up one of these alternatives since they sell at such bargain prices in today's digital world.
10-01-2016, 06:37 AM   #12
UncleVanya's Avatar
QuoteOriginally posted by ivanvernon Quote
I am myself considering picking up the mz-6 also. Just because I never tried it.
10-01-2016, 07:30 AM   #13
I don't think the MZ-6 is easy to come by.
10-01-2016, 01:21 PM   #14
What about...
...the SF series of cameras. You can select the aperture on those without moving from the A position.
10-07-2016, 12:23 PM   #15
I have the MZS and the ZiP (pz1), the MZS is a prettier camera, but harder to use and a lower spec. It does have the nice battery grip however. I have never had an MZ6, so I can't comment on that model.
I have a K100D with a pentamirror, and K20D, K5 and K3II with pentaprisms, and with identical lenses on, I cannot tell the difference.
50mm, aperture, camera, da, da lens aperture, love, mode, mz-s, pentax help, photography, pm, pz-1, pz-1p, shutter, troubleshooting
I am following this tutorial, but there is one step that does not work for me Neel1 Digital Processing, Software, and Printing 6 09-27-2016 08:33 AM
I am not a Luddite, but....... tennjed Pentax K-5 & K-5 II 9 08-12-2015 01:10 AM
Solved - What setting am I missing? (Images in PS CC look grainy, but are not) Sagitta Troubleshooting and Beginner Help 5 05-08-2015 07:22 AM
Hi, I am actually not totally new here but... Pentax-K Welcomes and Introductions 9 12-03-2014 12:43 PM
Yup, I am new to Pentax Forums, but not the Cameras! tonhill Welcomes and Introductions 3 06-24-2014 12:58 AM
All times are GMT -7. The time now is 08:58 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
