10-02-2016, 07:55 PM   #1
K-1 firmware update isn't working
Tonight I was trying to update my K-1 from version 1.00. I've followed Pentax' official instructions as far as Step 4: "Turn on the camera while pressing the MENU button." When I've done that, many times now, I just get the normal rear status screen, ready for shooting. According to the instructions, Step 5, I should see this: "'Updates the Camera Firmware' appears in the LCD monitor."-- but it doesn't. has anyone else encountered this obstacle? Please tell me what I"m doing wrong.
10-02-2016, 08:00 PM   #2
See the troubleshooting steps here:
Pentax K-1 Firmware v1.30 Released - Firmware Updates | PentaxForums.com
10-02-2016, 09:23 PM   #3
QuoteOriginally posted by Wheatridger Quote
Tell us how in detail you did it. What computer.
10-02-2016, 09:26 PM   #4
Thanks- a couple more times through the whole process and it worked. No idea why!
10-06-2016, 02:21 AM   #5
I have the same problem with my new Pentax K1. I am trying to up grade from version 1.0 to 1.3. I have followed all the steps exacty as explained in ricoh official site, but no success at all.
Each time what I see at the LCD monitor is the same as normally what everybody sees when camera turned on.
I need some help/explanation to this situation.
Thanks.
10-06-2016, 02:29 AM   #6
QuoteOriginally posted by aierturk Quote
Thanks.
Did you see my troubleshooting link? Check the filename, location, and extension. Check your battery level and make sure the card with the update is in the first slot.
10-06-2016, 07:27 AM   #7
K1 firmware update
Thank you Mr Adam for quick reply.After some more study I solved the problem.
Eureka Eureka
I have succeded to upgrade K1 firmware V1.0 to V1.30
I have to explain the reason why my previous attempts was not succesfull.
The reason was, my miss understanding about the ''SD card root''.
What I was doing copyng the '' fwdc228.bin'' file inside to the DCIM which was the problem.
Since what I was doing after formatting the SD card with the mouse right click I was copying the .bin file inside the DCIM.
Now open the SD card on computer with right clik, then DCIM file will be seen: After this just copy the subject file next to it.
Thats all. Rest follow the instuction.
I hope my writing is explanatory.
01-29-2017, 12:13 AM   #8
AYD
AYD's Avatar
I was copying the firmware .bin file to a new unused card that I formatted in the camera in slot 1 or 2, and then copied the .bin file to the root folder. On following the menu press and turn on, the camera would not got to the update firmware question. Did this 2-3 times, formatting the card every time and repeating the procedure. It took 2-3 attempts before it finally worked. Seems you must have a newer card and use slot 1 to format and update. Don't use slot 2 to format and don't use a card over 2 years old. I'm still not sure what the real issue is.
Everything works and love the camera. Just got a 15-30 and its a fabulous lens!
01-29-2017, 01:40 AM   #9
Bengan's Avatar
QuoteOriginally posted by AYD Quote
In-camera formatting?
01-29-2017, 02:33 AM   #10
clackers's Avatar
Just have it in slot 1.
You don't need to format it there, or even in the camera, a computer is fine.
Anyway, glad you're up and running!
camera, firmware, instructions, k-1, k-1 firmware, pentax help, photography, step, troubleshooting
A Standing Ovation for the K-1 Firmware Update 1.3 Profligatographer Pentax K-1 12 10-05-2016 10:16 AM
K-1 firmware update version 1.30 shaolen Pentax News and Rumors 15 09-20-2016 06:38 AM
K70 firmware update 1.1.0,DCU update 5.6.1 OoKU Pentax News and Rumors 4 09-07-2016 02:19 AM
Can't update K-r firmware from 1.00 to 1.15 ? derek45 Pentax K-r 4 07-04-2015 05:15 PM
Firmware 1.13 update stopped AF working on one lens only TimFAu Pentax K-r 5 09-25-2013 12:41 AM
All times are GMT -7. The time now is 07:50 PM. | See also: NikonForums.com, part of our network of photo forums!
