Originally posted by Nass Hello,
It maybe that you're suffering from slightly front or back focus, and/or that the miniscule depth of field meaning errors easily creeping in.
I'm curious though, what benefit do you obtain reverse mounting a DCR250 on 50-200?
Thanks,
What does the front or back focusing mean? and as far as benefits go I achieve greater magnification which is basically it. For example this image isn't cropped. I wouldnt have been able to take it with the lens mounted normally on my 50 mm and i cant mount it normally on my 50-200 because the adapter doesn't fit the 49 mm thread on that lens. however You just gave me the idea of does raynox make a lens adapter for smaller lens threads? would make mounting it easier than electric tap haha. I'm aware of the 43 mm thread on the raynox which i guess would leave about 6mm if not less of play room for an adapter.
---------- Post added 10-10-16 at 07:41 AM ----------
Originally posted by pacerr Possibly not optically centered and perpendicular to the lens axis causing a tilt/shift effect.
i didn't check to see if it was perpendicular ill check that.
