Originally posted by mcgregni I didn't, he seemed to have done it all right, but that little extra setting step would catch out plenty I'm sure!
Sounds like a well specified flash .... Am I right to think that the Promaster is a rebadged Tumax model?
I'm not sure who actually makes this flash. I do know that Promaster is not a manufacturer. They buy products from other manufacturers and put their name on them, just as Vivitar does. It very well could be made by Tumax.
So far, I like it. The only significant feature is seems to be lacking is wireless flash control. I have seen nothing in the manual about that.
For the earlier poster who was not familiar with HSS, it is a technique that allows flash pictures to be taken with the shutter speed faster than the camera's "synch" speed. On a Pentax dslr, that speed is 1/180 second. That is the fastest speed at which the shutter is completely open. At faster speeds, the trailing curtain begins to close before the leading curtain has finished its run. This results in a moving slit across the image sensor.
An ordinary flash fires once (aside from the exposure-control pre-flash) at the instant the shutter is fully open. HSS mode allows the flash to fire multiple times, as the shutter traverses the image sensor. The cost is flash intensity. An HSS flash is not as bright as an ordinary flash.
It also has less motion-stopping power. An ordinary flash may have a duration as short as 1/50,000 second. I think it is 1/20,000 on my Promaster flash. That will stop a bullet in flight. In HSS mode, the motion stopping ability is that of the physical shutter, which on most cameras is 1/4,000 or 1/8,000 second.
Someone on a forum somewhere did an experiment to demonstrate this. He shot a tabletop fan (the kind used to provide a breeze in a hot room). with an ordinary flash exposure, the fan blades were perfectly frozen. In HSS mode, the fan blades were completely blurred.
HSS is particularly effective as a fill flash in bright sunlight, to compensate for shadows that may fall across the face of your subject. In bright sunlight, a shutter speed of 1/180, even with an aperture of f/16 or f/22, may still be enough to overexpose the picture. By raising the shutter speed, you can control the exposure caused by the ambient light, while using the flash to fill in the faces of your subject.
