10-13-2016, 06:40 PM   #1
madison_wi_gal's Avatar
EXIF confusion - K-r can't decide what lens I am using?
Just received lens from eBay, Sigma 70-300 DG, and slapped it onto the K-r to take a few sample shots. I copied them to my computer and then, as I tend to do, renamed them using EXIF info.
<ExifTool:LensID> at f <ExifTool:Aperture> at <ExifTool:LensFocalLength> at shutter speed<ExifTool:ExposureTime>.PEF (or .JPG depending)
Anyway, I took 6 shots, and the first and last had correct LensID info but the middle 4 were kind of oddly confused, see attached.
Not a big deal since I know what I have but is my K-r being weird, the lens being weird, or do I need to be worried?
*** I note that it is not confused at 70mm but is at 300mm, I think I will take a few at other FLs and see what happens.
10-13-2016, 07:22 PM - 1 Like   #2
QuoteOriginally posted by madison_wi_gal Quote
at f at at shutter speed.PEF (or .JPG depending)
It's the lens ID that's ambiguous. The camera just records what the lens tells it
10-13-2016, 07:38 PM   #3
Kind of what I figured, but that leads to the question WHY is the lens confused about its identity? I gently cleaned the contacts on both camera and lens and took several more shots, it definitely has some identity crisis at FL's other than 70 or 300. I noted that the aperture ring was not locked at the A setting at first but that has no effect anyway as far as I know.
Anyway again not a huge deal, but none of my other lenses act this way (I pulled out my trusty 18-55 and on all shots it was perfectly self-aware).
10-13-2016, 07:44 PM - 1 Like   #4
Ole
Ole's Avatar
It is only certain third party lenses that lead to erroneous lens identification.
10-13-2016, 07:46 PM - 1 Like   #5
UncleVanya's Avatar
Many third party lenses use an id that isn't unique to them. When faced with this the camera tries but it isn't a mind reader.
10-13-2016, 07:51 PM   #6
It's getting the fundamental info correct at least. Well, one more reason to stay with brand name Pentax lenses.
10-13-2016, 08:00 PM - 1 Like   #7
dbs
Hi Madison Gal
Sigma lenses never know what they are on a Pentax Camera .
I have film era lenses and newish (post film ) lenses and very few know what they are !
So don't worry and just keep shooting.
Dave
10-21-2016, 07:28 PM - 1 Like   #8
I have found that it matters which PPE I am using. For example, I mostly use Photo Editor 10 which came with Windows 10. Using the right click on File Info, I will get everything but which lens was used. Now when uploading from MY Albums on this site, it always displays the lens information. Well, with the exception of a manual lens.
FastStones Image Viewer does a good job also, it does not provide the lens data, but will give all the necessary settings. Again, I get very good info., using My Albums.
Hope this helps,
Tony
03-01-2017, 09:02 PM   #9
Yup (reopening thread). My "new" (eBay) Tam 90 is clearly marked 272E but EXIF says 172E.
Sigh.
According to this the 172E and 272E have the same lens ID.
32 53 64 64 24 24 35 02 Tamron SP AF 90mm F/2.8 Macro 1:1 (172E)
32 53 64 64 24 24 35 02 Tamron SP AF 90mm F/2.8 Di Macro 1:1 (272E)
03-03-2017, 03:50 PM - 1 Like   #10
Wheatfield's Avatar
It seems to be a common problem with Sigma lenses.
I've always been of the opinion that Sigma is short for Significant Malfunction.
03-03-2017, 04:29 PM - 1 Like   #11
boriscleto's Avatar
Sigma often uses a generic identifier (early production IMO).
For example. My Sigma 10-20mm F/3.5 uses a 8.255 identifier as do at least 6 other lenses. So Lightroom identifies them as a Sigma 70-200mm F2.8 EX DG Macro HSM II. All of these lenses also have unique identifiers...
The Sigma 70-300 in the OP shares a 3.255 identifier with at least 8 other Sigma lenses...
I use a Lightroom Plug-in called LensTagger to correct this...I can use it to tag my manual focus lenses too
LensTagger Lightroom plugin
camera, exif, exif confusion k-r, info, k-r, lens, pentax help, photography, shots, troubleshooting
I am sick... I can't count my lenses and bodies anymore.. please help yshin621 Welcomes and Introductions 28 05-20-2015 09:39 AM
Macro Plant can't decide what it wants! whk1992 Post Your Photos! 6 08-29-2014 07:46 AM
I can't decide.. TcKay Pentax Mirrorless Cameras 6 05-06-2013 10:16 AM
can't decide what lens to buy, so I made a chart... khardur Pentax SLR Lens Discussion 27 04-28-2010 07:19 PM
All times are GMT -7. The time now is 10:58 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
