10-14-2016, 04:34 AM   #1
AF540FGZ not being triggered
Setup:
Pentax K5:
  • exposure: o (o) ((o))
  • _______this ^
  • manual mode
  • flash mode: flash on
  • ISO 100, 1/160, F9.0 (doesn't really matter what are these settings)
AF540FGZ:
  • manual mode
Problem: Flash is not triggering when shooting
I can fix this problem using A mode, but I'd like to use 1/x coefficient in M mode.
Please, how to make flash to trigger every time no matter what?
10-14-2016, 10:31 AM   #2
enoeske's Avatar
QuoteOriginally posted by AndreyS Quote
Setup:
Pentax K5:
  • _______this ^
  • manual mode
AF540FGZ:
  • manual mode
Are you giving the flash enough time to recycle? It can take a long time depending on power level and batteries used
10-14-2016, 01:37 PM   #3
QuoteOriginally posted by enoeske Quote
yes, the test button is glowing. The charging sound is absent, I mean it just came to the end.
So I guess it's a bug?
I think I'll make a video later on, so that everybody could see. Maybe I'm doing something wrong, but I strongly doubt it.
10-14-2016, 01:56 PM   #4
Senior Moderator
Nass's Avatar
hm must be a problem your end, I have a k5 with 540 on it on manual, and the flash shoots just fine...
10-17-2016, 01:13 AM   #5
KoT_BacbKa's Avatar
Test button is activated flash?
10-17-2016, 01:54 AM   #6
QuoteOriginally posted by KoT_BacbKa Quote
Sorry, I cannot understand your question. Please rephrase it.
I played around with mentioned setup - preparing for taking the video. The light button didn't work this time. When I click it -> LCD display goes off and then immediately (after ~0.5 sec) goes on. For now flash fires every time.
Also I cannot change the format in PTTL and M modes, when I click it nothing happens. Of cause I use always digital, just saying it, maybe it can help for troubleshooting.
2 days ago I was able to turn LCD off, in that case flash fired not every time.
Am I doing something wrong? Or maybe it works as intended, isn't it? I have never worked with brand new fully working flash. I need your help in guiding me to figure out whether the flash is malfunctioning or not.
Any input regarding for resolving this ridiculous issue would be appreciated.
---------- Post added 10-17-16 at 11:10 AM ----------
This undefined behavior just pisses me off. I remember when my good friend asked me to take pictures of her weddings. First 30 min flash just didn't work. And it is not the only case. I recalled the most significant one.
10-17-2016, 02:24 AM   #7
Senior Moderator
Nass's Avatar
Given the language issues, I think it'd help greatly if you made a video and posted a URL
-Nass
10-17-2016, 03:34 AM   #8
Sorry for that bad quality, k-5 is the only good recording device I have.
If something wasn't clear enough or some details are missing, please let me know
10-17-2016, 05:14 AM   #9
If I set C22 option to 3 (OFF) K-5's LCD and flashlight's LCD go off.
According to p.11 of af540fgz operational manual flashlight's LCD screen should not light up with K-5 when exposure metering timer is on.
As you can see on my video, LCD is lit no matter what in PTTL and M modes. It didn't light up in A mode though. It seems something is wrong either to the camera or the flashlight.
Anybody who has af540fgz, can you confirm this:
  • attach flashlight on the camera
  • turn flashlight and camera on
  • does light button switch LCD off/on in PTTL/A/M modes?
12-31-2016, 06:01 AM   #10
I cleaned up contact pads of flash unit as well as batteries. And it worked fine.
af540fgz, button, camera, click, flash, lcd, matter, mode, pentax help, photography, time, troubleshooting
HELP -- TTL flash not triggered by radio triggers Class A Flashes, Lighting, and Studio 10 11-24-2009 04:53 PM
Radio Trigger and AF540FGZ - Not working Peacekeeper Flashes, Lighting, and Studio 5 07-02-2009 05:54 PM
All times are GMT -7. The time now is 01:59 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
