10-17-2016, 04:53 AM   #1
K1 stuck directional pad buttons
Two of my directional pad buttons are stuck in the pressed-in position. It essentially renders the camera useless because I can't change any other settings due to this button being permanently activated.
I did shoot in the ocean last week and my camera certainly took some splashes. I had not had any issues until today but got a little bit of moisture on the camera and I am wondering if there may have been some salt under the buttons from the previous shoot which caused the buttons to stick from the moisture today. Has anyone had this issue and other than lightly rinsing with water are there any great solutions to this? My biggest concern is it happening again and being forced to give up on a shoot. I was unable to free the buttons while in the field today so I was forced to call it quits but I really don't want to risk a future occurrence.
10-17-2016, 06:15 AM   #2
UncleVanya's Avatar
Send it for service and use backup body. Rent if required.
10-17-2016, 02:43 PM   #3
gerardbaron's Avatar
Sorry I missed the word stuck.
10-17-2016, 02:48 PM   #4
UncleVanya's Avatar
QuoteOriginally posted by gerardbaron Quote
Press the small button on top of the up arrow pad
This button can also swich between the two SD card
When you read the card
How does that fix the stuck button issue?
10-17-2016, 03:29 PM   #5
Wingincamera's Avatar
If it is a grain of salt or sand stuck in the pad you could try a can of compressed air on it. I don't believe it would void the warranty and easy to do.
10-17-2016, 07:02 PM   #6
QuoteOriginally posted by Wingincamera Quote
Great idea, I hadn't thought of that yet. I did have a good deal of sand on much of my gear that day so it is quite possible there was some wedged against the button somewhere.
buttons, camera, moisture, pad, pentax help, photography, troubleshooting
To K1 or not K1 - that is the question? interested_observer Pentax K-1 78 07-15-2017 03:58 PM
K1 stuck in manual mode ukspeedtraps Pentax K-1 50 10-05-2016 12:41 AM
Random multi-directional button failure neuropol Pentax K-5 6 12-23-2012 06:15 AM
handheld flash, soft and directional? brandonbpm Flashes, Lighting, and Studio 5 09-16-2012 04:33 AM
Cityscape Directional, Directionless iocchelli Post Your Photos! 3 07-20-2010 07:39 AM
All times are GMT -7. The time now is 05:33 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
