Originally posted by Not a Number It's probably a case of the data pin on the mount not being shorted by the narrow mount of the M42 lens.
Most (almost all) M42 lenses have non-conductive bases, so the data pin is almost never shorted even with those lenses having a wider mount face. I don't have a K-1 in hand and should probably not comment further, but I will anyway. The behavior of recent flagship models is support for both green-button and DOF preview metering in M mode regardless of whether the mount face is conductive. The K-1 should follow this pattern.
Originally posted by Nebulous So after messing with my two different m42 mounts I can randomly get it to meter with DOF preview but it if you breath on it you get nothing. Too bad you couldnt force metering with DOF preview
Breathing on it should make no difference.
With the DOF preview switch full over, the EV bar should be visible and should reflect the current metered EV. If this is not consistently the case, you may want to contact Ricoh/Pentax support or your dealer. If all you want is metering without the EV bar, use the green button.
