10-17-2016, 05:51 PM   #1
K1 V1.30 shows Out Of Range in low ambient
This morning, me and my K1 went down to the harbour to photograph the sunrise. I arrived well before sunrise – in the dark with harbour lights and a high moon.
With the K1 set to manual, the viewfinder blinked the speed/aperture/ISO settings – “out of range” ? (oor) … and in the live view window, the oor settings blinked red. The internal exposure meter worked as normal and the exposures and pictures were OK too.
I reset the camera to its factory settings, changed the lens – Ptx 100mm ws, Ptx 18-105 zoom, Ptx 300mm F* - cycled the battery – still blinking.
I continued shooting and as the sky began to lighten, the blinking stopped.
Back home, I placed the camera under the bedclothes (hellish dark there!) and the “out of range” blinking returned – even with the the exposure meter reading +5. A slight increase in ambient light and the blinking stopped.
I have tried other settings M P Tav …. same problem.
With the camera out in normal room light the oor blinking is not evident – even when placing my hand over the lens – it seems as if there is some ambient light sensing happening – that is, the K1 senses a dark ambient and sets the oor warning on.
This is my first “dark” shoot using V1.30 firmware – I have not seen this behavior before.
Thanks for any help or comments …
PJ
10-17-2016, 07:08 PM   #2
photoptimist's Avatar
Interesting!
I've always been a bit ambivalent with how the Pentax metering system handled out-of-range exposure values. It blinks but displays numerical values nonetheless as if they were some wild guess by the metering system and the camera uses those values even if they are horribly wrong.
This new behavior seems more correct in that the camera is explicitly indicating the correct exposure is unknown because it is too dark. Presumably, a similar "oor" would occur in too bright situations.
But I can see how it would be frustrating because now I'll have to remember those "too low" values because that's often what I work off of in dark situations.
10-17-2016, 07:15 PM   #3
Tas
QuoteOriginally posted by pjaynz Quote
PJ
I was working out of Taupo a few years ago and recall the first time I heard 'Whakatane' on the weather report. Gotta love the pronounciation.
So far as the blinkies go, I've been pretty sceptical about them when reviewing images on the screen as I've seen over exposure indicated but when looking at the RGB histogram it isn't. These days I normally set the image preview to the RGB histograms and use the blinkies as a guide as they will help when I've got the screen brightness adjusted or exposure is off by more than a small amount.
Not sure if any that helps at all, but hopefully someone else will chime in and provide you some better feedback.
Tas
10-17-2016, 07:45 PM   #4
clackers's Avatar
QuoteOriginally posted by Tas Quote
AFAIK, it's always been pronounced that way, but prudish English administrators insisted it not be spelt phonetically!
ambient, camera, exposure, k1, k1 v1.30, lens, light, pentax help, photography, ptx, settings, stopped, troubleshooting, v1.30, warning
Anyone figure out a fix so .PEF thumbnails (from K1) show up in MacOS finder? cam_abyss Troubleshooting and Beginner Help 4 09-16-2016 06:13 PM
K5iis versus K1 ISO range Wild Mark Pentax DSLR Discussion 4 06-27-2016 12:11 AM
Old Car Photography - ambient low light interested_observer Photographic Technique 6 12-05-2012 05:54 PM
out of focus pictures in low light shots willwalker Photographic Technique 11 06-07-2011 05:23 PM
Comparison of K-5 low light focus accuracy with v1.01 and v1.03 of firmware tram57 Pentax K-5 3 03-20-2011 08:13 PM
All times are GMT -7. The time now is 09:48 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
