Those low prices for the the DFA100mm earlier this year were nuts. A few people pulled their used ones off the marketplace as a result. I'm not sure of the state of things now, or if we'll see those new prices again.
WR would be nice, but I haven't been shy about using mine in light rains, or snow or swamps and so far so good. The most worrying part is making sure the barrel is dry before changing the focus (it extends sooo much!), but the lens hood helps cover this in inclement weather.
I'm honestly not sure which version I'd get if I had to replace mine today, I do use a bellows occasionally so it's a toss up. If I had the DFA100 WR I suppose I'd also
need the DFA50mm macro (which also has an aperture ring). This combo makes the most sense now that I think about it, something for the field and something for the studio
Originally posted by Doundounba
BTW, I'd encourage you to actually check the magnification on the 50-200mm plus DCR-250 combo. I'd think that at 200mm, it's quite possibly more than 2:1. And I'd myself be interested in knowing the numbers for magnification at both extremes (50mm/infinity and 200mm/MFD).
Approximately,
At 200mm/MFD I get 1.96x mag.
At 200mm/infinity I get 1.56x mag
At 50mm/MFD I get 0.56x
At 50mm/infinity I get 0.43x
Working distance (distance from the front of the Raynox to the subject) at the 200mm/MFD setting was not too shabby, about 11cm. The DFA100mm at MFD + DCR250 gives 2x mag, but has a much closer working distance ~5.5cm.
