Originally posted by lithedreamer So I have my K-1 (36 MP on 35mm) and my K-30 (16 MP on APS-C), so I could either crop or use the crop body or use crop mode. One thing that isn't making sense here for me is the idea that you don't lose light when using a crop body. I've watched some of Tony Northrup videos, and he's talked about how when you use full-frame glass on crop bodies you should apply the crop factor to both the focal length and the aperture (my D FA* 70-200 f2.8 becomes a 105-300 f4.2, for example). That would mean that a teleconverter cuts less light that a crop body, as a 1.4 teleconverter extends the focal length by 1.4 but only cuts the light by 1-stop. I could be misunderstanding this, though.
- Regarding the impact of light on image quality, using a TC on FF sensor or using the same lens directly on a crop sensor, using the same exposure parameters would create any significant difference.
- Exception: when shutter speed is not an constraint, i.e lowering shutter speed one stop or more, then the FF IQ is supposed to be superior than the one on crop sensor.
-> TC on FF gives more options.
- Downside (specific to Pentax) is the TC does not fully cover the FF image circle, that should not be. Canon and Nikon TC cover FF image circles.
Example: on the K1 it is now possible to use the electronic shutter. When the lens and camera are on a tripod and the subject motion isn't an issue, it is possible to stop down the lens for maximum sharpness, use low iso, and slow down shutter speed in order to collect more light. I shoot f10, f11 or even f14 , ISO100, shutter speed 1/50 with the DFA150450 and TC on FF, with those conditions, image quality is significantly superior to a crop.
