Originally posted by psoo The main thing I notice is that the UV filter sharpens the image. Any diagonal lines that may be present are barely noticeable, if at all.
To be clear (no pun unintended
), most UV filters don't do this and I consider those that do to be defective. Ideally, I want no change in how the lens renders with and without the UV filter fitted.
I've had four that displayed this diagonal lines issue - one Kenko, two lower-cost generic examples from eBay, and one Hoya HMC. Hoya are my favourites, and generally they cause little or no degradation in IQ on wide angle, normal and short tele lenses. At long tele focal lengths - eg. 300mm - they will typically introduce very, very minor softening of fine detail in distant subjects (a good test for me is photographing the chimney stack on a neighbour's house about a hundred metres away - the moss that grows on the brickwork shows up any softening effect really well).
Originally posted by psoo If you don't intend to use your UV filters, send them to me and I'll slap them onto some my lenses to sharpen the images.
No chance!
I prefer to keep them on my lenses and take them off indoors or if the weather's dry and relatively calm
