Originally posted by cardinal43 Have you had any problems with the one for the K20D? I'm interested in one as I have the K20D, but I'm also seriously considering a K-3 II. Any possibility the one for the K20D will also fit the K-3 II. Thanks.
I had my K20 for 3 years and sold it about 5 years ago. The Kirk L Bracket fit absolutely perfect - like a glove. When I acquired my K5 I did put the K20 bracket on it for a couple of weeks. The K20 was a larger body than the K5 so, there was some space between the bracket and the body on the side. It was usable, but I finally ordered the K5 Kirk L Bracket and sold both the K20 and the bracket. My current K5 Kirk bracket also fits like a glove on the K5 body. Kirk does an excellent job with their brackets - I do really like them.
As to the K20 bracket fitting on the K3II body, probably. From what I remember, the K3 is a tad larger than the K5 but smaller than the K20. So, I would imagine that you would experience the same situation as I did, with some additional space on the left hand side of the camera. It still does work, but it just looks a bid odd.
Kirk designs and then builds a run of product early in the body's life span, then sells them until their are gone. Then waits for the next body. When I purchased the K5 bracket - they had already sold out of the K20s. I see now looking at their web site that they have plates for a number of Pentax bodies, but only L brackets for the K1. I also see that they have an universal L bracket - which I have never used or looked at. YMMV.
I also see that the K1 L bracket is of a different design - essentially two pieces. My only experience is with the single piece of CNC aluminum stock.
