Originally posted by enyaw Hi psoo, I have the camera set up already. I'm waiting on the weather to improve so I can do some real world tests. Thanks, I'm quite sure the viewfinder will brighten up outside. Indoors usually lacks enough ambient light. I was just curious is someone with experience had an answer and wanted to know if the flash would help also. The onboard one that is.
Hi enyah, I think I gave you some incomplete info on my technique for using a manual lens on my K50. I have carried out more tests and actually find that I must only set my camera selection dial on "M" to get correct exposures. When I set the dial to "Auto" in preliminary tests I found that the exposures were fine, but it was just a fluke. The camera should only be set at "M". Here is my new procedure for using manual lenses on the K50:
1. Set the camera to M (Manual use)
2. On the lens, set the aperture you want to use (Also select the ISO on the camera)
3. Hold the exposure button half-way down and manually focus the lens. You will hear a beep, and see the green hexagon in the viewfinder, to show you are in focus. I have no problem in focussing even when the lens is stopped down and the image is dim. It just takes a little longer to focus.
4. Press the green button and you will hear a loud click, which I assume is the camera setting the exposure time
5. Take your finger off the green button and press the exposure button all the way down and you will take the photo.
I tried to take some flash shots using the above procedure under dim-light conditions, but it does seem to work. The camera takes a picture as if the flash gun is not deployed and I get a long exposure plus the flash. The result is overexposure. I guess the flash cannot be used when the camera is on M.
Hope this helps.
