Show Printable Version 8 Likes Search this Thread
02-11-2017, 04:09 AM   #46
Hi altopiet, the like was for the informative response. Not for the bad news no lol
---------- Post added 02-11-17 at 04:11 AM ----------
psoo, If my k50 was out of warranty I'd use my 50/50 rule. I won't pay to repair anything that's 1/2 the cost of the item. Actually it's a 60-40 rule. Depending on the item.
---------- Post added 02-11-17 at 04:17 AM ----------
It's a shame pentax didn't get rid of the problem for good after the K30 had the issue. How could they continue producing another model with the same issues.
Template:Pentax digital interchangeable lens cameras - Wikipedia
although the timeline wasn't that great, must be a money generating issue which is what business is all about. But at what cost
02-11-2017, 06:13 AM   #47
altopiet's Avatar
QuoteOriginally posted by enyaw Quote
Thank you, an extensive thread discussing the problem, and some peoples feelings regarding it... K-30 / K-50 Aperture Block Failue - Repair Solution available - Page 25 - PentaxForums.com
I agree with your sentiments completely
02-14-2017, 10:26 AM   #48
QuoteOriginally posted by psoo Quote
I have some good news. I was experimenting with my K50 and the manual Tak M 50mm, f/2 lens. As I said previously, the combo worked well and it circumvented the aperture block problem. On a whim, I changed the manual lens to my Tak 18-250 mm lens and, hallelujah, the lens worked perfectly. The aperture block problem fixed itself. Maybe the jiggling around with the manual lens unlocked something and jolted the K50 back to normal. Has anyone else experienced a Pentax camera self-repairing the aperture block problem? I'll keep you posted to let you know if this is a temporary or permanent fix.
Hi Folks, I'm sad to tell you that my K50 broke down again and the aperture block problem re-emerged and the camera is again giving vast underexposures. I guess it was too much to expect that the camera would stay repaired. Well, I'm back to my old strategy of using manual lenses on the K50 and auto ones on my Kx
05-03-2017, 04:26 PM   #49
Hi I need a clarification. I know the lens works in M, and my second option is AV or TAV are they the same? The guides say AV but what is TAV then?
Thanks,
55mm, aperture, apertures, beep, button, camera, cost, day, flash, focus, ie, indicator, issue, item, lens, light, pentax help, photography, pm, post, press, rule, shutter, troubleshooting
Manual Focus Tips braver Pentax DSLR Discussion 15 01-20-2016 08:41 PM
Grassroots Auto Racing - Manual focus tips 89Y49Si Photographic Technique 40 07-23-2015 04:39 AM
Manual focus tips on K30, 18-135mm WR lens jaikumarr18 Pentax K-30 & K-50 22 05-03-2014 04:17 PM
Tips shooting with a manual focus lens? Javaslinger Troubleshooting and Beginner Help 6 01-11-2011 06:37 PM
Manual Focus Tips menappi Photographic Technique 26 12-08-2008 06:08 PM
All times are GMT -7. The time now is 02:21 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
