Originally posted by enyaw What settings should I use to get the best results with my K-50? I'm planning on taking the smc 50-200mm DA with me.
What are you going to shoot? At night, interiors, wildlife, portraits, sports, landscapes, etc? Are you going to print your work or is it just for the internet? Do you use a post-processing software like Lightroom or Photoshop? Based on the very limited info you wrote, here are some very basic guidelines:
a) Shoot in RAW DNG format if youʻre using a serious post processing software and intend to print your work. Or shoot RAW PEF if youʻre going to use Pentaxʻ Silkypix app. Change your Color Space to AdobeRGB.
or
If you want to use your photos straight out of the camera with no ability or intent to post process on a computer, then shoot jpegs with the "best" quality setting. Use the default Color Space of sRGB.
b) What is your level of knowledge in terms of the relationship of ISO, shutter speed, and aperture?
If the answer is low, then just use the green AUTO setting on your mode dial on the top right of the camera.
If the answer is medium, then use the TV mode with a telephoto zoom like the 50-200mm and use a minimum shutter speed that matches or exceeds the focal length of the lens. So if youʻre zoomed out to 50mm, use at least 1/50"; if zoomed in to 200mm, use at least 1/200" or faster. Variables include camera movement, subject movement, subject speed-direction-distance, and as previously mentioned the focal length of the lens. Turn off SR (shake reduction in the menu) unless you do not have a tripod and need to handhold shots with slow shutter speeds of static subjects without increasing ISO.
c) Use the lowest possible ISO that allows you for a normal exposure with your chosen shutter speed, and only increase the ISO if your images are too dark, or you need a faster shutter speed or smaller aperture (bigger f/stop number).
Originally posted by enyaw piggy back, what settings do you guys use for shooting winter/snow pictures. 18-55mm wr kit lens, ie white balance etc
Cameras tend to under expose bright white landscapes such as snow or beach scenes. Therefore if youʻre shooting RAW, use around 1.5+ EV exposure compensation. If youʻre shooting jpeg, then you use the SCN mode and set it to the Surf & Snow.
I generally leave white balance on AWB (auto white balance) but if you want to create a panorama by stitching images together, set it to Daylight or even Cloudy to increase the color temperature a bit for the bluer high altitude light.
I apologize in advance if this is way too basic advice, but assuming youʻre new to your K-50 and photography in general, hope this helps. Note that the S mode on a Nikon (Shutter Priority) is the same as the TV mode on a Pentax (Time Value).
