12-18-2016, 03:27 PM   #16
swanlefitte's Avatar
Could also be the bulb. Again strobist is a place to start. Google strobist fash bulb replacement.
---------- Post added 12-18-16 at 05:02 PM ----------
Heres a great resource.
Notes on the Troubleshooting and Repair of Electronic Flash Units and Strobe Lights and Design Guidelines, Useful Circuits, and Schematics
12-18-2016, 07:32 PM   #17
UncleVanya's Avatar
QuoteOriginally posted by swanlefitte Quote
Thanks.
08-08-2020, 05:41 PM - 1 Like   #18
Yes this is an old thread, but I was experiencing the same problem as the OP and now it is fixed. I will share all I did, in the hopes that this may help someone else, because I was about to sell it as broken for a small amount on eBay, and now I am happily able to use it!
Nutshell:
- power on
- press Mode button to cycle through the modes
- when get to P-TTL, the Ready lamp (Test button) lights up for about 1 second, then goes off
- with flash on camera, get ready to take a shot that will require flash -- half-press shutter and hold half down
- cycle through modes again; when you reach P-TTL and the Test button lights, fully depress shutter to take photo
- flash fires!
- flash becomes Ready and STAYS ready as it should -- and never returns (so far) to that bad state it was initially in!
More things I tried:
- fairly fresh batteries
- since I'd bought the flash used and the prev owner had left batteries in it, and a battery got corroded, I used steel wool to clean the battery contacts well
- tried cycling through other things, zooming, etc.
- when I once saw the light on and pressed Test and it fired, it did NOT return to normal operation; it only did when I fired the flash from the camera, taking a photo
- turned no and off several times
- it is possible that I initially mounted the flash on the camera without pushing it FULLY into the hotshoe; it may have had imperfect contact, therefore, with the camera
Note: I have not tried wireless mode.
My guess is that the flash got into some sort of incorrect internal state, and whatever I did allowed it to fire and reset to the correct state. It lost its mind, then got it back. But that is just a guess.
As far as I know, the flash has not been abused or handled roughly, but as noted, I was not the original owner.
Hope this helps someone!
08-12-2020, 03:19 PM   #19
UncleVanya's Avatar
Update: I sold the bad unit to someone needing physical parts.
af500ftz, af540fgz, batteries, body, bulb, camera, fire, flash, onboard, pentax help, photography, strobist, test, troubleshooting
AF540FGZ not being triggered AndreyS Troubleshooting and Beginner Help 9 12-31-2016 06:01 AM
Metz 44 AF1 Will not fire the flash kevingun Flashes, Lighting, and Studio 6 09-02-2015 10:07 PM
Metz 58 v1 will not fire Hiroshi Troubleshooting and Beginner Help 3 05-16-2015 10:47 PM
K-50 low light will not fire a shot? focusr3 Pentax K-30 & K-50 9 12-24-2014 01:48 AM
K5 battery depletion message/shutter will not fire Scenesaver Pentax K-5 8 01-26-2014 08:09 AM
All times are GMT -7. The time now is 11:11 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
