12-18-2016, 02:37 PM   #1
K-1 Playback stopped working
Suddenly my K-1 playback button has stopped working. It worked maybe 1 of 10 tries for an hour or so when I noticed today and now I think I can not playback anymore. It takes pictures fine. Last firmware 1.4 , I use san disk extreme pro cards. I have formatted cards, tried different cards, reset, different lenses. Nothing fixes it. Anything else I can try before sending it for repair? It has failed me just I need it the most traveling overseas.
12-18-2016, 04:06 PM   #2
CDW
If you haven't tried it and I'm not sure if it is possible. Try reloading 1.4.
12-18-2016, 10:41 PM   #3
Otis Memorial Pentaxian
Sorry, but I have to ask...Are you certain there are images on the card to review? Are you also certain that the playback button is the only function that is not working?
12-19-2016, 04:41 AM   #4
QuoteOriginally posted by Rudy Quote
For what its worth, this issue seems to been reported in DPREVIEW (approx 2 months ago) albeit different firmware rev and different cards/speeds. As of now, no fix has been reported.
K-1 Playback button issue?: Pentax SLR Talk Forum: Digital Photography Review
12-19-2016, 05:25 AM   #5
Yes I am sure there are images on the card because once I noticed the failure to switch to playback I started to test formatting the card, reset, different card and lenses etc I was able to see my new test pics when I was able to playback in one of ten trials for example. Initially it would switch to playback after a reset or pulling battery out but lately not anymore.
Yes it seems that only the playback button is the only function not working. More specifically I would say when the playback button is pressed the camera fails to switch to playback mode resulting in continue to stay in camera mode or a a couple of times on switched but black screen and a couple of times on successful display of pics taken I every 20 trials.
12-19-2016, 06:45 AM   #6
arnold's Avatar
My K1 snapped out of playback several times (showed menus instead). Finally settled down. Glitches?
12-21-2016, 04:20 AM   #7
today 3 days later my k-1 playback button is working normally again. The only difference I can say I have between the last weekend and now is that I was at 11,000 feet above sea level when it was not working and I am now at 600 feet above sea level when it is working today.. I am not saying this is the cause of this very strange behavior, just stating my observations.
camera, cards, k-1, k-1 playback, pentax help, photography, playback, troubleshooting
Help! My K-50 has stopped working correctly and the screen is acting crazy pandazerg Troubleshooting and Beginner Help 14 03-23-2016 12:19 PM
Rikenon 50mm 1.4 - Iris stopped working, stuck wide open ChristianRock Pentax SLR Lens Discussion 9 03-22-2016 08:10 PM
K-01 dial (shutter, aper. zoom) stopped working haaldemir Pentax K-01 5 06-09-2015 02:59 PM
Pentax K-3 Screen Burn-In/Auto Off Stopped Working ShaburnBurn Troubleshooting and Beginner Help 3 04-29-2015 08:36 PM
K-5 rear display stopped working nbu Troubleshooting and Beginner Help 10 04-07-2013 02:24 AM
All times are GMT -7. The time now is 03:03 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
