Originally posted by tcom The only issue is that the LCD screens (both top and rear) get slower to react as the temperatures drop
LCDs (Liquid Crystal Displays) as the name suggests has liquid in them. It can and will freeze at its freezing point. If that happens it can start to slow down like tcom mentioned. The fluids/crystals don't align to the electrical signals being sent to them when frozen. This may temporarily cause displays to go wonky, malfunction. It usually should not harm if you do not force it to function as in turn the LCD display off if you think it may freeze. Some poor quality LCDs may permanently (cheap digital watches) go bad if they freeze and refuse to thaw back to their original state.
Originally posted by tcom Be careful however when entering a warm heated room with a camera which stayed out in the cold for several hours, humidity to immediately condense on the body and might even freeze. So, before entering a heated room with a freezing cold camera, put it back in the camera bag, close it and leave the gear in it for a few hours to let the camera come slowly back to normal temperatures.
Or just use a zip-lock bag to bag your camera before you enter a humid or warm room. I do that all the time and is easy to carry around. Saves you a lot of headache from condensation which is inevitable in such a transition.
Also avoid lens changes if you can. I use one lens for the entire shoot and then don't change out until I am in a place devoid of odds.
Reason: Added another tip
