Originally posted by onlineflyer I also have the K-5iis and the DA 300mm lens, along with a 1.7x AF adapter. Why the 1.7x? Becuase I also have the A*300mm and K 200mm F2.5 that are manual focus lenses. I can use the 1.7x on all three lenses,although I never use it on the DA 300mm. If I only had the DA 300, I would have purchased the 1.4x since they are all (Kenko, Sigma, Tamron, Pentax) true teleconverters that allow the lens to focus, rather than the adapter..
so the 1.4 allows the lens to focus and the 1.7 focuses for the lens. amd I getting that right ?
---------- Post added 12-21-16 at 08:52 PM ----------
Originally posted by narual You could use the
Focal length comparison tool, Tamron USA, it doesn't have birds, but it should give you an idea.
It's not a very large difference between 1.4 and 1.7 on the 300mm though. You're going from a 5.2 degree angle at 300 to a 3.7 degree with the 1.4, and the 1.7 gets you to 3.1 -- and given teh comparitive quality between the 1.4 HD and the kenko 1.7, you're probably better off with the 1.4 and doing a little cropping. (the Kenko 1.5 gets good reviews though, and gets you to 3.4 degrees, while being considerably cheaper than the 1.4 HD)
that'svery good information. I can see where the 1.4 would likely do the job for me then. I don't need a lot of extra reach, just a little. and I would hate to degrade the sharpness of this 300F4 by over doing it. I can get within 60 ft of most the small birds during the season, and crop up. I would likel to reach in a little more for detail, and the the extra bokeh, sometimes the bokeh on the 300 is a little grainy
