Show Printable Version 13 Likes Search this Thread
12-21-2016, 07:44 PM   #16
QuoteOriginally posted by p38arover Quote
To be honest, I don't know why it has to be turned off.
In the K-01 Manual: "
Using the Shake Reduction Function
to Prevent Camera Shake
12-21-2016, 09:38 PM   #17
E-man's Avatar
I'm lazy and leave SR on, even when using my tripod. Hey, you never know when an earthquake might hit, so it pays to be prepared, right?
12-21-2016, 10:11 PM   #18
QuoteOriginally posted by E-man Quote
that's funny. I have a few time taking photo during earthquake strike. I found that if it shook hard enough for human to feel, SR won't help!
12-21-2016, 10:15 PM   #19
QuoteOriginally posted by Professor Batty Quote
The MeFoto tripod I have has a place on the underside of where the legs attach to attach a small carabiner, I attach my camera bag to that and it effectively increases the mass. SR off.
I've tried using that with the 70-200, but I've noticed that my backpack is often heavy enough to put significant strain on the tripod. The other day when I tried it, the centre column suddenly collapsed on me, which was...startling.
12-21-2016, 10:55 PM   #20
Huy
I usually use 2 sec timer when shooting with the tripod. But I forgot to do it 2 days ago
12-21-2016, 11:05 PM - 1 Like   #21
QuoteOriginally posted by pakinjapan Quote
Hi Pak,
I can vouch for your opinion.
In about 1992 ( I forget exactly) , I was presenting, with a colleague engineer, a training course near Ikebukuro
I took this photo with the Pentax ME Super and the SMC Pentax 1:2 50mm and the Pentax AF16 Flash.
After that a tremor shook us all and I recall the building columns,
like the one shown in this photo, twisting all along the building.
https://app.box.com/s/2bihp0353890b6f8edgvvpyym89m7e5w
I recall that all the trains tripped off and we had to wait in client's factory for about 12 hours before
all clear.
12-21-2016, 11:30 PM   #22
Closed Account
I usually forget to turn off SR.
Hi Ron. The SR is designed to counteract vibration, as you know. BUT, without any vibration present the SR while trying to detect vibration can actually set up its own. As it is trying to stop its own vibration and can't, it can set off a feedback loop on itself and actually damage the SR. Here is an old thread that covers it pretty well. Some of the posters in that thread are in this one as well.
https://www.pentaxforums.com/forums/58-troubleshooting-beginner-help/246727-w...ke-tripod.html
EDIT - " potentially " damage instead of " actually " damage intended. Apologies for any confusion caused.
12-21-2016, 11:47 PM   #23
QuoteOriginally posted by pjv Quote
I doubt that it works like that.
Can you cite a ref?
The K-01 manual page 100, for example , seems to explain it.
Regards,
12-21-2016, 11:55 PM   #24
That doesn't sound right. Has anyone ever actually broken their SR by doing that?
12-21-2016, 11:58 PM   #25
Closed Account
QuoteOriginally posted by wombat2go Quote
Can you cite a ref?
Regards,
A short ' captain google " search found this. As there will always be photographers who dispute all manner of theories, SR is specifically designed for hand holding the camera. Cheers.
How to Make Sure You are Using Image Stabilization Correctly
12-22-2016, 12:41 AM   #26
I recommend you read your Pentax Camera Manual before pontificating on here.
12-22-2016, 01:27 AM   #27
Closed Account
Apologies if you thought this was an attack wombat2go, as this was not my intention. Camera manuals state the SR should be turned off when using a tripod, yet many know this and still leave it on. That is what I meant by " disputing " theories. I was not being purposely disrespectful.
12-22-2016, 03:20 AM   #28
Closed Account
QuoteOriginally posted by lithedreamer Quote
What I should have written, but did not in my haste was, has the " potential " to damage the SR. The feedback loop is a real occurrence as a consequence of the sensor setting up its own movement in trying to compensate for perceived movement. That is why some complain about blurry images even though they used a tripod - the camera was still set with SR ON. If you read the old thread and the other link I have provided, it is recommended that the SR be OFF when using a tripod. Apologies for any confusion that I have caused ( inadvertently ).
12-22-2016, 03:41 AM   #29
I typically would have the SR off when I'm on a tripod, as I am using the self timer or a wireless remote to trigger the image. If I didn't use those and was more using the tripod the way you would use a monopod, then I probably wouldn't hesitate to use SR. SR is there to counteract shake. If you are rock steady, then it can actually make images worse, but if you are shaking some then it should help.
12-22-2016, 04:23 AM   #30
ffking's Avatar
In terms of set up, I prefer my heavy old metal Gitzo and Arca Swiss Monoball when using the the K-1 with the 70-200, but my mid range aluminium Manfrotto (055 XPRO series) + XPRO ball head can certainly handle the combo with a little more care -as others have said, I mostly use the 2-sec timer, so no SR, but the differnce between really sharp and not really sharp with a lens of that quality makes me reluctant to take any chances with non-recommended procedures
camera, fyi, movement, pages, pentax help, photography, reduction, shake, sr, time, tripod, tripod with sr, troubleshooting
Buying a Yongnuo flash, any recommendations on a tripod bracket? keanex Flashes, Lighting, and Studio 4 03-15-2016 05:38 PM
Gear you take on a shoot? Heavenly Creation General Photography 7 02-06-2016 08:59 AM
Do you turn off SR when using a tripod for landscape? enyceckk Pentax DSLR Discussion 22 11-12-2015 09:08 AM
How often do you have a tripod with you? Vylen Pentax Camera and Field Accessories 60 10-02-2013 04:33 AM
Do any of you use a handheld meter in conjunction with your dslr? slackercruster Photographic Technique 9 05-07-2012 09:04 PM
All times are GMT -7. The time now is 12:24 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
