Originally posted by grumpyone I have a K 30 and all my lenes are manual and fit and work fine,but one it is my Vivital 120-600 zoom also 5.6 to 32 rapture..It is a k mount but it also has a piece on the ring that sticks out futher than the rest almoust quarter way around.That is what is stopping that lens fron mounting on the body.My question is there a adaptor for this or a different ring?Please help this is my favorite lens to use.Thank you
There should be several JIS cross type screws (not Phillips-head!) on the aperture guard. You can unscrew those and remove the guard. You can then use a dremel to cut the guard down to a size that will fit, or just use the lens without it.
